Engine noise, Brake noise
"1) The service bulletin number for the "Engine Ticking Noise" is "P-B-07.00-21D-DTB"
2) Buzzing noise from Sensotronic brakes
There's a new bulletin that just came out for those of you that hear a buzzing noise from your brake system. A pulsation damper is to be retrofitted into the suction line near the main SBC hydraulic unit. Order No: P-B-42.46/27a"
After they looked at it, I was told the noise from the engine is "normal". AMG engines are not "as smooth" They said they checked the bulletin and the motor mounts problem only applies to SL, E, CLK 500 and same for brake noise. I'm confused now, guys help me out here!
What about the brake noise? any of you have that?
