Vibration under braking & at 80mph - fixed
So been having a bit of an issue with my car and vibration under braking from 'speed' and generally vibration at ~70-90mph range.
The vibration at 80mph was resolved with road force wheel balancing of the FRONT tyres despite no shimmy in steering wheel felt at all. In the end all 4 were road force balanced - but the fronts were the culprits.
The braking issue was first thought to be warped rotors or poorly fitted rotors. I checked all that and looked all fine and re-seated the rotors for good measure. I then discovered some play in the front bearing. Test by holding the wheel at 12 and 6 and simultaneously pulling and pushing both points into and away from the car. RHS was a definite but light clicking, the wheel almost not even seen to visibly move. The left similar but less so (almost undetectable but was still there) - curiously there was no clicking detected when doing the same procedure from position 3 & 9 on the wheels. Recalibrated the front bearings (a few videos on this out there), and car is back to silky smooth at speed and braking. I had to rotate the rhs bearing retainer maybe 1/4 turn to recalibrate it and the lhs about 1/8 of a turn as a guide.
I was quite surprised at the bearing wear as the car only has 26k miles on it - but in the end was a super easy fix. Can't tell you how smooth the car feels now - thrilled to bits.
So just a heads up if you are facing similar vibrations ... road force balancing and be sure to check bearings before you tear into replacing bushings.
PLATINUM SPONSOR
Glad you found the problem. Did you change both inner and outer bearings or exactly what bearing was it?
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
