BOOST numbers with fixed pulleys
Old 11-15-2018, 12:36 AM
newe55guy's Avatar
2006 BRABUS E55 K8 & SL500
Who has numbers based on pulley size?
I have a fixed 74 now getting 16/17 psi
I have the new VRP 70mm and wanted to know what boost it makes
THanks
also reading based on obd2 port blue scan
Old 11-15-2018, 12:40 AM
newe55guy's Avatar
maz boost 16psi
IAT 64
Old 11-15-2018, 12:57 AM
drothgeb's Avatar
2005 E55
You are going to limp mode your car with any more pressure. You will need a map clamp. Do you have long tube headers yet?
Old 11-15-2018, 01:04 AM
newe55guy's Avatar
no I dont. I have the raceIQ tune for it and it runs 10.5 AFR now... I assume that is a tunning issue they can fix when i go to the smaller pulley?
mods include:
Rebuilt SC
Rebuilt Motor
Rebuilt Trans
3.5" Intake
Midlength headers
74mm fixed pulley
tune from race IQ
DRLs
Euroteck diffuser carbon
Carbon Side splitters
E63 Bumper Carbon Spoiler
carbon mirror covers
Custom headlights HID Kit
Secondary HE Superflo pump
Trunk tank and install kitV3 HECustom
3" Exhaust
550 cc injectors
adapter harnesses
Looped rail
One step Colder Plugs
Intake Scoops
3 piece pulley set
Belt Wrap Kit and green belt
82mm TB with ported snout
TCU
Powdercoated Surge tanks
Wrap in cooper
Carbon interior
Caron steering wheel
Freenavi with data logger
Stop Tech Rotors, Pads,lines
Goodyear Eagle® F1 Asymmetric 3
Old 11-15-2018, 01:49 AM
drothgeb's Avatar
2005 E55
No, it can't be fixed via tuning you'll need a MAP clamp. Don't put that new pulley on
Old 11-15-2018, 10:03 AM
failboat's Avatar
none yet
with headers 74 and stock 154 crank you should be around 14.5-15 psi, stock 154 crank and 70mm with headers will put you around 15.5-16psi so about a 1 psi increase
Old 11-15-2018, 01:21 PM
Das_it16's Avatar
2004 E55 AMG
That chart is just an estimate and not accurate. Elevation, DA, certain mods like headers, ported heads and throttle bodies change this. I had a 74 in the past and only saw 8-9psi peak boost. My buddy that lives near atco was seeing 16-17psi with just a 77 with long tubes and a 82 tb. This is why you need to datalog and not guess.
Old 11-15-2018, 01:26 PM
Das_it16's Avatar
2004 E55 AMG
mods include:
Rebuilt SC
Rebuilt Motor
Rebuilt Trans
3.5" Intake
Midlength headers
74mm fixed pulley
tune from race IQ
DRLs
3" Exhaust
550 cc injectors
adapter harnesses
Looped rail
Intake Scoops
3 piece pulley set
TCU
Wrap in cooper
Carbon interior
Slap on a set of long tube headers to drop the boost a bit more over the mid lengths. Contact Race IQ to adjust that tune a bit to lean it out closer to low 11s.
Old 11-15-2018, 01:30 PM
drothgeb's Avatar
2005 E55
x2. If you are seeing 16-17 PSI right now with the 74mm through torque, that means your ECU is seeing it. Car goes limp mode if the MAP sensor sees right around 17.5PSI so you are already very close (all it takes is one blip split second single read of too much pressure). If you go to 70mm you will limp mode the car on WOT pulls. Unless you either get a MAP clamp or get some legit long tube headers and get a couple of PSI decrease from the mids to the LTH (I dont know how much more flow you will achieve from mids to LTHs, so still a little bit of a gamble if it doesn't drop pressure enough.)
failboat's Avatar
none yet
thanks for the info I never took this into consideration, what is DA? i see it mentioned here all the time
Old 11-15-2018, 01:34 PM
Das_it16's Avatar
2004 E55 AMG
I went from EC mids to Maximizer long tubes. I saw around 1psi in boost drop.
Old 11-15-2018, 01:47 PM
Das_it16's Avatar
2004 E55 AMG
Density Altitude. It helps racers confirm the quality of the air. The higher the DA the less oxygen is available for the engine to use. Less oxygen, less power and slower times. The lower DA the better. Sometimes is so low it goes negative. When its negative expect to run better. Better air, more boost, more power, faster times. There are apps available for your phone that helps give you DA. Drag Times, That Racing Channel are example of apps.
Here's a video that explains it more in detail:
Old 11-15-2018, 04:51 PM
oneslow55's Avatar
E55 amg
Fyi ,your car is not seeing 18 psi boost ,your in - vac ..lol
Old 11-15-2018, 04:55 PM
drothgeb's Avatar
2005 E55
He didn't say 18, he said 16-17 peak. In torque that little red mark (that is sitting right on 16psi in his pic) indicates the peak value seen during that session (and the indicator can be manually reset if you want to).
newe55guy (11-24-2018)
Old 11-15-2018, 04:57 PM
oneslow55's Avatar
E55 amg
No way he's seeing that boost with mids.
Old 11-15-2018, 05:27 PM
PieRat's Avatar
CLS55
I have a 77 SC and stock crank, gutted exhaust to muffler with the kleemann mids...I see like 13.7 actual boost, the torque app sees a spike sometimes a touch over 14 but I don't really count that I just assume its for a brief second at like gearshift or some ****.. How do you get so much more boost than me? I'm at sea level too! Pretty sure I don't have airleaks, havent smoke tested but exhausted a can of brake cleaner checking for intake leaks..
Old 11-24-2018, 08:20 PM
newe55guy's Avatar
Why would I lie lol
Old 11-24-2018, 08:24 PM
newe55guy's Avatar
yeah i am not going to now thanks
anyone want a fixed pulley new from VRP
185$ plus shipping
Old 11-24-2018, 08:43 PM
oneslow55's Avatar
E55 amg
I could care less ,but you would hit limp at 17 psi FYI .The Elm is not accurate and only way your seeing that high is top of 4th gear maybe to 5 th gear
Old 10-16-2020, 08:56 AM
CrossfireDiva's Avatar
337whp & 375whp Crossfire SRT-6, Chrysler Crossfire (NA), 2005 556whp E55 AMG
My E55 is seeing 19psi and no limp mode at all. I'm stacked 83/180 and LTH.
Old 10-16-2020, 08:58 AM
I consistently saw 17psi when I first started racing my E55 and zero limp mode ever. I'm now 83/180 stacked and seeing 19psi in the heat. I expect 20 or more when it cools down.
Old 10-16-2020, 08:59 AM
Vac is always negative. That red mark is boost.
Old 10-16-2020, 10:28 AM
drothgeb's Avatar
2005 E55
Interesting. I wonder if it's a model year/firmware version type thing.
Old 10-16-2020, 07:36 PM
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
How do you get that read out into the car's dash screen? I have for 4 years now, run a Race IQ tune on a 74mm fixed pulley with EC stage 2 parts, no cats. I love the jumpy throttle response you don't get with the clutched pulley. I have read the the efficiency of the blower starts reducing rapidly if you spin it faster than a 74mm pulley does.
Old 10-16-2020, 09:24 PM
drothgeb's Avatar
2005 E55
. That's a torque display on an android head unit. And this is a couple year old thread ;-)
This is my set up:
Quick Reply: BOOST numbers with fixed pulleys
