ECU failure or?
Old Dec 10, 2020 | 12:32 PM
E42AMG???'s Avatar
E420
I’ll get you a picture later
Old Dec 10, 2020 | 04:09 PM
MartinWake's Avatar
CL55
okay
thanks
Old Dec 10, 2020 | 04:38 PM
E42AMG???'s Avatar
E420
Originally Posted by MartinWake
okay
thanks
you’ll have to pull a panel off after you get the carpet out of the way
Old Dec 11, 2020 | 01:28 PM
MartinWake's Avatar
CL55
Weird thing that we found out... when its doing all the crazy stuff if you go and disconnect injector 8 everything goes back to normal but as soon as you reconnect it all the lights come back.
We did try another stock injector same thing.
Also I am not sure about this but when you pin the connection from the ecu injector pin (negative) to the injector plug (positive) and the key is not turned the multimeter beeps only when it touches the plug (positive)
but when the key is turned all the way you can put the positive on any part of the engine and it will beep.
