Boost Problem
Old Nov 22, 2020 | 05:24 PM
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
Boost Problem
Hello Everyone!
Previously i had UPD bwk on E55 with 180mm weistec cp , it had 550HD belt , last week i added upd 83mm sc pulley to match the combo 180/83 with retune plus 550cc injectors , Long tube , 82mm tb and one step colder spark plugs, i tested the car on 550HD it had boost only 11.5-12 which I suspect slippage , so i ordered 545HD belt , i tried it boost 12 and later on after 2 pulls the belt has shredded into pieces...
IAT is perfect as i have 2 intercoolers and tested in cold weather, no high IAT.
Also the same problem on another car with methanol+ice tank , max boost also 12 psi , tested the fuel pump while on dyno , giving 5.5 bar.
What do you think ? Any help is much appreciated
Old Nov 22, 2020 | 06:14 PM
SICAMG's Avatar
2005 e55 AMG
Don't know why the lack of boost but maybe the belt was night on the ribs completely and came apart ???
Old Nov 25, 2020 | 05:31 PM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Originally Posted by ChiCho55AMG
Hello Everyone!
What was your boost before doing the 83mm sc pulley upgrade? And at what altitude/elevation are you testing at?
