2003 E55 amg traction issues
Old Nov 28, 2020 | 06:05 PM
Kyle Harris's Avatar
2003 AMG E55
looking for tips on adding traction, my car just peels out everywhere when driving aggressively if im not super careful with the throttle. its fine just driving normal but any time i hit it hard i end up breaking loose and back end kicks out. any one else have this issue? my buddy recommended better tires, and there is an "esp malfunction" on my cluster so im going to get that checked out, but any info on this would be helpful.
Old Nov 28, 2020 | 06:57 PM
tw2's Avatar
tw2
Everyone has this issue. Better tires and LSD is about all that can help. If you live somewhere without much rain, drag radials would be ideal.
Old Nov 28, 2020 | 07:06 PM
2003 AMG E55
any reccomendations on tires
Old Nov 28, 2020 | 07:08 PM
tw2's Avatar
tw2
I run bridgestone potenza's re003 or s007a (indy 500's in the US) but they are only good in warm weather. I won't be getting them again. I would say pilot sport 4 would be a good choice.
Old Nov 28, 2020 | 07:13 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Leave ESP on and it will stay straight 😁 talking tires, do you drive in the rain?
Old Nov 28, 2020 | 07:14 PM
2003 AMG E55
does the height / width of the tire make much difference? i have on federal ss 595s in the back(not by choice) they are 265/35/18 was wondering if i should get that same size
Old Nov 28, 2020 | 07:15 PM
2003 AMG E55
im not sure if the esp even works. it says i have an esp malfunction. and the esp off button doesnt do anything
and yes it rains here a decent amount. but i dont drive aggressively in the rain.
Old Nov 28, 2020 | 07:28 PM
tw2's Avatar
tw2
Height won't make any difference. Width can make a small difference but it is still roughly the same contact area. 265 is the widest that should be put on a stock rim. You can fit 275 but it is outside the maximum recommended.
Old Nov 28, 2020 | 08:45 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Definitely get codes from the esp/suspension module scanned, ESP is shockingly effective at preventing this. Otherwise you have 500hp and an open diff, no getting around that.
If it consistently steps out the same direction also check suspension bits and rear shocks. I had a leaking rear shock that caused the same side pull and replacing them made the car launch in a more controlled fashion.
You could have an ABS sensor bad etc that isn't triggering the rear calipers to even wheel spin out as they compensate for the open diff.
Lastly, I do have to say better tires were the single best improvement to traction I've made, I got the Pilot 4s at Costco, spendy but the traction (wet and dry) is just phenominal.
Old Nov 29, 2020 | 01:58 PM
PieRat's Avatar
CLS55
You Need esp working. Even when ESP is disabled via the button it is still acting as your (****ty) electronic differential. As stated above without it your open wheeling probably spinning up the weakest wheel and the esp system isn't intervening? Even with the system working you will be rear traction limited due to the nature of the v8 torque profile. You need a limited slip differential to address the issue as much as can be done..
Old Nov 29, 2020 | 03:25 PM
M5 LOL's Avatar
05 E55 (06 E55 RIP)
granted im at stock power level, but my car is the fastest with ESP left on.
Old Nov 29, 2020 | 10:37 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Install a limited slip differential or, more cheaply, put your car in "comfort" mode using the button on the center console. I find I succeed more often in street challenges starting in 2nd gear. Less wheelspin and still enough torque and horsepower to shut down the ...(censored for protection). FWIW, I never street race. Seriously. You can go to jail for that so never street race.
Old Dec 1, 2020 | 01:19 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Federal 595 doesn't grip very well. Those are more drifting tires instead of grip. I have Toyo with 295/30/18 to get a decent grip.
Old Dec 6, 2020 | 11:54 PM
rusbel's Avatar
2006 E55 - obsidian black, all options except pano roof - gone but not forgotten
I run Firestone Firehawk indy 500 all around. they stick like glue. had them om my supercharged Mustang as well and was happy with them.
Old Dec 7, 2020 | 05:03 AM
feeshta's Avatar
2006 E55 AMG Kombi
My wagon actually seems to put the power down quite well, at least on the summer tires. Winter tires not so much. Guess the extra bit of weight over the tail helps with traction.
Old Dec 7, 2020 | 09:29 PM
Windowguy's Avatar
2012 Audi S4 & 2008 E63 AMG
I have the Indy 500s also and they are pretty good on my'08 E63. My power is a little higher in the RPMs so I can get wheel spin in 2nd when i go over 3000 and if its cold I can spin in 3rd.
I would also make sure the alignment is good.
Rob.
