Surging power after VRP SC pulley install
'05 E55 *Wagon*
After installing a VRP 76mm clutched pulley, I've been experiencing a very odd issue. On every upshift, the SC disengages for ~0.5sec before re-engaging (the car has a RaceIQ ECU tune for this specific pulley. And I've confirmed it's not the tune by going back to the stock pulley and having the issue go away, only to reappear once the VRP pulley is re-installed. It also has the RaceIQ TCU tune). It's extremely jerky to drive because the SC is engaged, there's an upshift (and it disengages), followed by a slight pause before it re-engages. It's like power -> no power -> power, all in about a second. Extremely jerky, almost like a student driver learning how to drive a 5-speed. I thought it might be belt slip, so I installed a BWK, but it made zero difference.
I've had zero luck contacting VRP via phone, but I'd like to try exchanging this pulley for another one. Before I bark up that tree, anyone have any ideas? It's annoying af, and literally difficult to drive on rainy roads, which in the PNW are going to last for another 6mos....
Have you measured the pulley gap? Aftermarket pulleys tend to sit further out so if you reinstalled the same shims it may be too large of a gap and make engagement harsh. You should be able find gap specs in a quick search, I don't remember them off the top of my head.
Also, the smaller pulley makes a lot more boost, which will affect the torque management in the TCU (most noticeable after shifts) so I'd highly recommend the zerocat (a member on here) TCU tune as it basically gets rid of that, something that RaceIQ can't tackle with ECU tunes alone.
99% of the time it's not tune related but more so a error on install or car your car had a small existing problem and the smaller pulley aggravated the situation. Check the gaps and intake leaks.
maw1124 (01-11-2021)
Are you data logging ? Need to see what the TB is doing on shifts , the added power could be messing with tq management, need to see your boost psi and where it is , hitting the rev limiter could do this also , no data logging your flying blind
he says every upshift but maybe he meant every WOT upshift. if its shifting fine medium throttle or when commanded to earlier in the rev range via Manual mode paddles (During WOT) then torque management and you need a zerocat tcu tune (do not get another vendors tcu tune they don't remove torque management like zerocats). If its having problems with EVERY shift could be a fault with pulley.. I do recall someone having a lemon pulley from VRP once. if I recall the new one fixed there issue whatever it was..
checking gap is good but I'm sure VRP instructed that in their install instructions so you've already got that on point..
'05 E55 *Wagon*
I also have the RaceIQ TCU tune, which I imagine should have addressed any potential trans issues, but I'm still new to the M113k platform so maybe not?
RaceIQ has a really good reputation AFAIK, and I purchased the ECU and TCU tunes at the same time after sending them the pulley specs, so I would be surprised if they flashed a TCU tune that was incompatible with the pulley. I also tried resetting the trans adaptations but that made no difference. The zerocat TCU tune sounds awesome, but I'd hate to essentially throw away the $300 RaceIQ tune after just a couple of months.
i fixed my lag actually in the tune...Your spec is to close that will cause issues too..aim for .028 to .032
Timing corrects lots of things
hey man try running the 76mm pulley with the stock tune see ifit works. Probably safest to only do minimal wot runs like this but car should still be pretty safe as it can read the boost off the map and fuel somewhat accordingly.
Some cars don't seem to like raceiq tune i could never get them to work in my car fuel trims off by 15%+ and the car would drop out of gear at WOT shifts seemed to over rev and hit a failsafe i had to restart the car to get back into gear due to limp mode I guess...maybe similar issue for you? Tony tried a few things to fix then gave up no refund so raceiq suck in my book but many happy customers so jury is out on that one.
I'd try resell the TCU as suggested and get a zerocat tune.
Eurocharged tunes always been bang on for me and worked flawlessly for the past 6 years or so and I bash my car poor girl..
fyi that advice you gave make no sense i would not load a stock file and do wot on 3 to 4 psi extra boost..That's the first i heard that about race iq as i ran it before.
99 ford lightning
raceiq sells the ndash just get the whole set up from him and log it Tony uses that as well makes life easier on both ends get the bung welded in for the wide band too.
'05 E55 *Wagon*
I've been driving with a 76mm pulley from VRP with the stock tune for a few days. I'm not sure we're experiencing the same issue, but I'm still getting the same SC delay that I was before the smaller pulley; but at least the belt slippage/chirp is gone.
I'm taking my car in tomorrow to install the tune and will have them look at everything to see if there's a way to fix the annoying lapse in power when the SC engages.
Fortunately for me, it only occurs one time if the car has come to a stop. After that, it's fine.
'05 E55 *Wagon*
Solved!
I spoke with Anthony at RaceIQ, and he informed me of the ECU adaptations the M113k uses. Frankly I had never heard of ECU adaptations. Transmission? Sure. ECU? Not so much. He figured that would be a good first place to start. I borrowed a Foxwell tool from a friend and sure enough, under the ECU section of the MB Tools, there were the 3 adaptations and a reset function. Reset all 3 (timing, a/f, and one other that I don't remember) and the car drives perfectly now. No jerkiness, no weird SC engagement, just freight trains of power! So for anyone experiencing something similar, try this first.
Solved!
Solved!
Which Foxwell scanner (model number) was able to do the reset?
