Problem with Bi-Xenon Auto Leveling
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hi, my headlight auto level is working wrong. On the first startup left headlight only goes up and a bit down and stays there (aiming at the trees) while the right light works fine. And when I restart the car everything goes back to normal. It's annoying to start the car two times every time I want to drive. Does anyone have any ideas why this is happening?
Made a video to showcase this problem:
https://drive.google.com/file/d/1qNh...ew?usp=sharing
Received 1,487 Likes
This place is a joke.
The motors inside the headlamp go bad. Solution is to replace both headlamp assemblies $$$$, or take them apart, disconnect the height motors and then manually adjust the lights to the proper level and leave them alone.
Sorry did you watch the video? The only right headlight has a problem on the first startup. When I shut down the car and turn in back on headlight levels up evenly. When it levels up.. I can shut down the car as many times as I want and it will level up.
But when the car sits for 5-10 minutes, on the first startup it aims right headlight higher.
There was a fix for the motors, using washers. I'll see if I can find the thread.
Found it: https://mbworld.org/forums/cls-coupe...motor-fix.html
