Should I replace this piston
Replace it.
If you don’t it will score the cylinder bore, then you’ll have to have the cylinder honed, to remove the scoring.
PLATINUM SPONSOR
Replace it! The damaged area will also cause hot spots and lead to detonation.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
