P0505 82mm throttle body
guessing p0505 is from my 82mm throttle body, car is really lumpy at idle. Is there any fixes to this issue? All the post I’ve seen are really old so not sure if there is a new fix out there.
Yo thank you so much, this fixed my issue with the idle and especially the hiccup when shifting. It also fixed the issue where when you let off the gas from WOT throttle it would slug you forward. Thanks, man!
