NEW TO MB! UPGRADING MY E55!!
The E55 AMG Parts Heaven
Email us your questions and all will be answered, Info@vrpspeed.com
https://www.vrpspeed.com/product-cat...55k-amg-m113k/
*******UPDATES!!!***********
Everything has arrived!
Aftermarket parts:
83mm Supercharger pulley (Thanks to Amir_AMG)
Long Tube Headers
Bosch Injectors 550cc
Heat Exchanger PLM
Johnson CM30 Pump
Carbon Fiber Intake Tubes Carbonio
RaceIQ Tune Stage 2
MK-Ultra Custom TCU
And I'm changing the head gasket (left/right), engine mounts, Air filter + carbon cabin air filter, NGK OEM Spark Plug LFR6AIX-11, differential oil 2xmobil1 75w-90, 0W-40 advanced full synthetic motor oil + 93oct (for tuning with RaceIQ)
And as I mentioned before, the car is getting a paint job, I bought Jet Black (Bentley Continental GT) and Acid Green (porsche) for the brake calipers. Next week the paint job will be finished, and before repolishing the car I will take it to the mechanic shop to install everything.
**PICTURES**
Mann Oil Air Carbon Cabin Filter Service Kit + NGK OEM Spark Plug LFR6AIX-11
NGK OEM Spark Plug LFR6AIX-11 + Bosch 52lb 550cc fuel injectors
Engine Oil Level Sensor
Supercharger Pulley Belt Combo AMG + 83mm Supercharger pulley
Full Synthetic Motor Oil 0W-40
TRQ Oil Filled Hydraulic Engine Motor Mount Pair
Starter Motor
Elring Head Gasket set
Carbon Fiber Intake
Longtube Headers
RaceIQ tune
Aftermarket parts:
Long Tube Headers
Heat Exchanger PLM
Johnson CM30 Pump
RaceIQ Tune Stage 2
MK-Ultra Custom TCU
**PICTURES**
Starter Motor
Carbon Fiber Intake
Longtube Headers
RaceIQ tune
The following 2 users liked this post by E55FR34K:
Fountain35 (04-17-2021),
uzzle7 (10-27-2023)
#36
Left - https://www.ebay.com/itm/Left-Head-G...K/173709877397
Right - https://www.ebay.com/itm/Fits-1999-2...4/292747766558
#38
I think you need valve cover gaskets not head gaskets?? The valve covers leak and oil runs down...
https://www.youtube.com/watch?v=RQoXjoigJNE
Luckily the car is still in the paint shop, tomorrow I will go to buy the valve cover gasket! thank you so much!
#46
Looking good! Just curious why didn’t they pull the left mirror, door mldgs and rear bumper cover off?
A lot apart and those few things would have been better. Also the door mirrors have rubber seals where they meet the door that usually deteriorate and need replacing.
#47
The left rearview mirror is not in good condition, if we removed it we were going to have a problem when we put it back, what I did was to order another one together with the rear bumper trim set, I will save paint so that when it arrives I will only have to remove it and install it.
The rear bumper had a small crack where it meets the center trim, I had it repaired and painted and thought about ordering the trim but what I will do is cover the trim with plastidip
The door mldgs, I honestly don't know why we don't remove it, we always do....uhggg
Next Tuesday I'm going to take it to the mechanic shop to install everything I bought, then back to the paint shop to repolish and shine it.
The TCU is almost here and I already have the RaceIQ tune cable.
tlambert (05-01-2021)
