When to upgrade stock injectors?
I was wondering as to when do you upgrade the stock injectors.
The car has the following mods:
- Euro charged mid length headers, with no cats so straight piped.
- 77mm super charger pulley
- Large heat exchanger
- Johnson heat exchanger pump ( changing to Bosch 010 soon)
- 1 step colder spark plugs
- K&N drop in filters
Also, if you ever plan on running full e85, or ethanol blends, you'll want larger injectors for that too, possibly with a upgraded fuel pump.
With your mods, you're nowhere close to maxing out the stock injectors. And as a side note, I would advise against "one step colder plugs." MB decided on a specific heat range for a reason. Very, very few of us have M113k-powered cars modified to a degree which warrant a cooler plug. Cooler plugs are used to reduce the propensity for detonation when running things much harder. Colder plugs on a stock engine or one with mild modifications is just asking for fouling plugs because of deposits that collect on the plug which won't burn off as part of the normal combustion cycle. Now if you throw a Weistec charger with a small pulley, full exhaust, aggressive tune, and other supporting mods then that may warrant a colder plug.
Don't just throw things on the car that take you a step backward because it's popular or a vendor offers it.
Do you even have a tune?
When I got the tune I did tell them I had 1 step colder spark plugs.
These were installed by the previous owner, the previous owner had it tuned from eurocharged as well, I had to get a new tune with rear o2's on for emission, now am back on the tune that the previous owner got.
Would you recommend removing these and going back to factory spark plugs.
also I am planning a coolant system refresh this weekend, since the radiator is over 15 years old and not sure when the rest of the parts were changed. The car runs around 96-97 C in the city ( ambient in mid 90 F), do you think that is normal or is that high ?
Will look into the duty cycle this weekend when I can get my hands on a snapon scanner.
I do not believe that I need bigger injectors with the current mods, and I am not planning on modding it further other then switching to coilovers, just wanted to be sure that its not something that I should be looking into.
Coolant temps: Factory thermostat is 190F/87F so I would expect temps around that. Sounds like you may be running a tad hot but I'm not sure. Again, Google is your friend.
Try some Google dorking. Yes, that's actually what it's called. For example, plug "site:mbworld.org E55 coolant temperature" (without quotations) in the search bar on Google. This will limit your results to this site and give you plenty of reading material on the subject.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
