Hemi powered AMG?
Old Jul 13, 2021 | 01:34 AM
Hemi_Doc's Avatar
W211 E55
Hemi powered AMG?
Yes you read that right.... hemi powered w211 E55.
This is stage 1 of the process.... the questions.
I understand some of your questions are why? The E55 makes enough power as is & if you want a charger than just buy one. Yes that maybe true for you but not for me. I like my E55, & the power isn't much in today's market. A biturbo v8 will smoke a e55 & the limits on the newer v8s are much higher.
ultimately the goal is to make a sleeper. Now u are thinking "its a amg everyone knows it's fast".... that maybe true but remember in 2021 it can easily be smoked. No one will think it's a low 9 high 8 second car.
ok enough with the lip service
the power plant plan
hellcat engine stroked to 426 (or stock bottom end) with a 4.5l Whipple (possibly stock to start)
all can get me over 1000rwhp with little effort.
Fitment is going to be great, frame rails are the same width as a charger. Transmission is going to be a Nag1. The Nag1 is a 722.6 but the Chrysler version and can hold the power. Drive shaft shop axles & drive shaft to transfer the power & LSD with stock gearing... why? The amount of torque will nearly double with the power I plan to make so I would like to use it.
fuel will be something I will likely borrow from the aftermarket hellcat world.
If you don't know the w211 & hellcat car are very closely related....
Management
That's my issue. I know Chrysler/hemi wiring & can bus but not the benz from this era. I will not use a hellcat pcm because it's too new & far down the evolution branch to adapt to the w211. So I will be forced to use a early hemi pcm likely from a 6.1 srt vehicle. But with using that pcm I cannot control the hellcat stock blower. They do make stand alone to control the blower but I can sell the stock blower & add a few grand & upgrade to a 4.5l Whipple. I would have to go inside the motor & change the crank wheel. So I would likely stroke it....
I would like to use my stock MB key & get keyless go to work. I want my dash to would aswell along with as many stock functions as possible including AC.
Do anyone has a PCM pin out for a 03 E55? I can't find it on alldata. What I wonder if I pin in the PCM will it work. The 6.1 pcm doesn't use a built-in TCM & uses an external one that looks exactly like the stock 722.6 one.
The mechanical parts are worked out... it's the electrical part on the benz side I'm not sure about.
What speed is the PCM bus using for communications? 4.5V communications at the "star connectors"?
I understand that forms are dying off so I will try my best to visit every Monday.
I can be reached at codegreenlite@gmail.com for faster communication, or Facebook Hemi Doc. Thanks for reading this very short paragraph lol
Old Jul 13, 2021 | 05:11 AM
tw2's Avatar
tw2
Sounds like a fun an unique project, awesome stuff. I have trouble getting the power down with mild mods, hopefully you live somewhere that you can cruise around with slicks all day.
Old Jul 13, 2021 | 09:33 AM
APBTdogman's Avatar
05' E55 - 22' Jailbreak Hellcat OTW
Awesome!
Old Jul 13, 2021 | 09:42 AM
Hemi_Doc's Avatar
W211 E55
It's been retired from daily driver status for some time. I will do coil overs & would run multiple tunes for street, prep & no prep events.... definitely would love to take it to a TX2k event & FL2K.... I will sell it likely after a year of driving it once completed.
Old Jul 13, 2021 | 09:53 AM
tlambert's Avatar
2005 E55 AMG
Sounds interesting. Keep us posted on the progress.
Old Jul 13, 2021 | 09:58 AM
Naeblis's Avatar
2009 E63
Absolute mad lad. Look forward to seeing this develop. Hope someone can help you out with the technical specs you're seeking.
Old Jul 13, 2021 | 10:34 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
this is awesome, but honestly if I were going to go through all this work anyway, i would've chosen a smaller, lighter MB to start with; like a w208 or w202.
Old Jul 13, 2021 | 10:44 AM
Hemi_Doc's Avatar
W211 E55
it would cost more money because I would have to buy one. Then I would run into higher cost of drive shafts & Axles because they would need to be custom. This is a street car at the end of the day.. I like the w211 better anyways. When I bought it 4 5 years ago.... hemi wasn't in the plans....
I have a full race car build after this one.... 1500hp + hp. Will be all mopar.
Old Jul 13, 2021 | 11:19 AM
Sulaco's Avatar
gotcha, gonna be a riot when it's done!
Where are you located? What will become of the original E55 parts? (motor, trans, ECU, etc) Do you have a stock E55 bumper you'd be willing to part with?
Old Jul 15, 2021 | 06:00 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I put a Holley Dominator EFI on my W208 CLK55, but it doesn't communicate over the CAN bus at all. You might reach out to the Therapy on Wheels people in Australia. They put a Hellcat engine in a W209 CLK, and I think it does talk on the CAN bus, at least somewhat.
https://www.whichcar.com.au/news/hel...r-in-the-build
Old Jul 16, 2021 | 12:08 PM
thovey's Avatar
F350 E55 E39
Eager to watch this interesting project. Much thanks to the OP for sharing.
Old Dec 20, 2021 | 06:23 PM
Hemi_Doc's Avatar
W211 E55
Awesome news. I have part's but I'm also too busy to install them. I an currently looking for a local fabricator to make my motor mounts. I have some long tubes for a charger complete trackhawk drive train. I'm glad that the car is factory super charged. That saves money on sourcing heat exchangers, pumps & routing of icebox.
Power levels has went up to possible 1500hp. I goal it to get it running first so a stock old 5.7 will do. I have several hemis around pretty much all sizes from old 5.7 new 5.7, 6.1, 6.4, 6.2 hell a 7.0.
I've had several failed attempts of project cars over my youth. One thing I did want keep go fast part's. From meth kits, fuel systems, & a lot of hemi parts. Pictures will be coming soon.
