Whipple 3.8L E55
Old Nov 16, 2021 | 04:20 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
31 psi on a 3.8L is over 1,200 whp...i'd guess 1,400-1,500 whp
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Nov 16, 2021 | 04:28 PM
chawkins2001's Avatar
2006 E55 AMG
It's big power no doubt, did I miss the fuel you are using, I am assuming it's corn?
Old Nov 16, 2021 | 04:41 PM
99lightning's Avatar
99 ford lightning
just buy another one you know you miss these cars
Old Nov 16, 2021 | 05:28 PM
jamesge's Avatar
2005 mercedes e55 amg
Thank you
Old Nov 16, 2021 | 05:31 PM
jamesge's Avatar
Originally Posted by SICAMG
Wow 31psi on 10.1 compression !!
Also looks looks the front bumper crash bar is modded or removed all together ??
Still there and split open where you see the H/E. Needed the crash bar to mount to.
Old Nov 16, 2021 | 07:36 PM
jamesge's Avatar
Real po
Old Nov 17, 2021 | 02:19 PM
  #32
hachiroku's Avatar
SPONSOR
did you have to move up to a triple fuel pump config?
__________________
-BARRY
Old Jan 9, 2022 | 07:10 AM
  #33
SICAMG's Avatar
2005 e55 AMG
Any updates ??
Old Apr 3, 2022 | 11:34 PM
  #34
2006 E55 AMG
Any updates?
Old Aug 22, 2022 | 07:00 PM
  #35
SICAMG's Avatar
2005 e55 AMG
This car just went 8.48 at 167mph on lower boost !!
Old Aug 22, 2022 | 07:03 PM
  #36
remix405's Avatar
2006 E55 AMG
if anyone wants to check it out on IG
View this post on Instagram
Old Aug 23, 2022 | 02:52 PM
  #37
eightysixtuned's Avatar
W211 E63 AMG
cnc billet aluminum block which resembles a Mercedes AMG McLaren SLR block. yowzaaaaa
Old Aug 24, 2022 | 04:35 AM
  #38
suicidal4life's Avatar
2001 E430
And 419 cubic inches which is 6.8 liter.
Old Aug 25, 2022 | 07:33 AM
  #39
RNS-11Z's Avatar
09 C63
Faaarrrkkkmee
Old Aug 26, 2022 | 07:58 PM
  #40
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Anyone wanna try and guess how much $$$ is invested in this motor? I'm betting easily $60k. A CNC billet custom block???
Old Aug 26, 2022 | 09:12 PM
  #41
E55Greasemonkey's Avatar
This place is a joke.
It's not an E55 anymore, just a 211 body with an altered drivetrain. Meh.
Old Aug 27, 2022 | 07:58 AM
  #42
Sulaco's Avatar
I just noticed that it's a stand alone ecu with the entire drive train gutted and swapped for drag racing norms. I respect the power plant but the car is otherwise just an E55 shell? Does anything else on the car work?
Would love the idea of that block being available to those of us who want to build a 750hp E55 without fear of popping the stock block.
Old Aug 27, 2022 | 12:00 PM
  #43
SICAMG's Avatar
2005 e55 AMG
750 hp out of a stock block sleeved is very doable and for 2,600.00 all done. A billet block is way up there in power....1,500 - 2,000 hp easy and that's a whole other level for sure cost wise.
Old Aug 27, 2022 | 01:53 PM
  #44
M5 LOL's Avatar
05 E55 (06 E55 RIP)
ah come on, it just a fully built and bored m113, m155(block) is just a fancy'd up m113k. its got a built trans and built rear end. its essentially what LS guys call "cam only".
Old Aug 28, 2022 | 01:12 AM
  #45
Sulaco's Avatar
Taking notes....
I've got an E55 wagon, but with a rebuilt title (somehow all the paint is original, and no it wasn't flooded). Part of me wants to yank the motor, sleeve it, get a whipple, and take the thing up to 700-800HP and just daily it. It's already got the normal mods (pulley, tune, cooling, headers) but since the resale value is already pathetic compared to clean title wagons, I should just enjoy it and beat the brakes off it.
Old Aug 29, 2022 | 12:04 PM
  #46
jamesge's Avatar
The car started as a sleeved block that I had o-ringed and step decked. I even had the block HIP'ed. It was also a Southern Hot Rod War Viking built 722.6 along with stock diff with custom 300M axles...
When I started adding boost, over 25lbs, the block couldn't hold it. I ripped out the threads on 8 head studs (the block did not give way, the heads were lifting by ripping the threads). The alusil can NOT handle 30lbs boost. I had the BEST 722.6 trans that money could buy and I granaded the input and output shafts (also 300M). I turned up the boost and tried launching the car at 4k rpm, and blew both axles out from under the car. The stock ECU: it cant do the different paramaters needed when trying to safely put 30+ lbs boost at the car.
If anyone has the goal to go well over 1000whp, the stock equipment is NOT capable unless there is significant engineering and re-design. What I have done, is exactly what places such as Texas Speed, LMR, etc have done; completely redeveloped the platform so that one CAN exceed the OEM design limits.
Yes, everything in the car still works; CANBUS, radio, ice cold A/C, factory NAV, sunroof. I put the street wheels on, take the parachute off, and noone would know its a 7 second car.
Old Aug 29, 2022 | 12:12 PM
  #47
AMG_55_cruiser's Avatar
2004 CL55, 2003 SL55, 2017 S63 Cabrio and 2009 G55
what is your parts list for 750HP to the wheels? Bigger pistons alone are almost $2600! Head work another $1500+ unless doing the work yourself…thanks
Old Aug 29, 2022 | 12:53 PM
  #48
Sulaco's Avatar
holy crap, that's extremely impressive. Any vids of this thing on the track??
Old Aug 29, 2022 | 01:52 PM
  #49
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
... What I have done, is exactly what places such as Texas Speed, LMR, etc have done; completely redeveloped the platform so that one CAN exceed the OEM design limits...
Was this just a personal project for you, or is this billet block going to be commercially available at some point?
Old Aug 29, 2022 | 03:34 PM
  #50
SICAMG's Avatar
2005 e55 AMG
My bad ....worded that wrong...
Block sleeves cost me $2,600
Pistons, $2,400
Rework rods,balance,polish,cryo treatment and WPC treatment came out to $550
Ported head on your own time, the sanding, cutting tools plus a valve job and keepers,springs, retainers,coated exhaust ports $1,000
A one off block is probably 10-$15,000 ...just guessing.
