E55 tires
Old Aug 3, 2021 | 06:18 PM
Fountain35's Avatar
E55 tires
I have a set of Michelin A/S 3plus tires on my E55, stock sizes. The front are in good shape but the back are getting to the point of replacement. The tires have ~17000 miles. Michelin no longer makes the tire so I guess I could replace the rears with Michelin A/S 4's but then I'm mixing tires by axle. OK to mix?
I also have some larger SL550 rims I could "up size" all 4 tires and call it a day.
Stock E55
245/40/18 Front
265/35/18 Rear
Versus
SL550 Rims
255/40/18 Front, (it seems you need a 3mm spacer)
285/35/18 Rear
Rambling a bit...
Old Aug 5, 2021 | 07:25 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Mixing AS3 and AS4 is probably alright. People have mixed far, far worse.
Old Aug 5, 2021 | 10:18 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
But when you have the opportunity to correct this, I would.
