Whining sound (probably transmission?)
Hello guys I have not been driving my car too much but when I do I like to downshift to hear the exhaust anyways I have noticed the whining sound that usually happens on all auto cars when downshifting is a little louder then usual. I will post two video links with the sound, hopefully you guys can hear it and point me in the right direction. I suspect its the transmission because it does not happen in park or neutral. My car is a CL55 AMG
Thanks!
Thanks!
All I hear is a lot of exhaust. That car is loud !!
If it does not do it in P/N than could be planetary gears but....you would hear noise all the time and it's rare that they go like that.
https://youtu.be/ul23BggiMOI
https://youtu.be/EESooOzRRTc
one video is next to a wall the other is not
Got it. When was the last trans fluid change ? Sounds like the converter is starting to go. That's the sound they make but.....if the filter is "cogged" a little it will starve the pump and converter for fluid and make that noise, sort of, as well.
I have not owned this car long enough to have changed the fluid, but I did some work and I needed to add some new fluid back in. I checked the level and it is still at the max. The transmission still feels the same as it has always felt.
biker349 (09-19-2021)
Edit: I took apart the filter and this is what it looks like, the other videos are of the pan. I am getting so may mixed responses, some people say my trans is done and others say its normal wear for the filter to pick that up. I do beat on the trans a lot but it never ran dry, the day it gave the most problem I had actually added more trans fluid so it might have over filled. Let me know what you guys think. I will start with the basic and put a new filter and fluid and see what happens..
Video 1:
Video 2:
The following 2 users liked this post by MartinWake:
biker349 (09-19-2021),
CLSSUPERCHARGED (02-15-2022)
