Small plastic clamp - Part Number question
Does anyone know what the part number for this plastic hose clamp/clip/separator is? I have looked on the parts sites, but cannot find it.
I was changing the supercharger oil today and broke it. I like to keep the car correct and really do not want to use a zip tie or just leave it off.
Well, since I couldn't locate the part online, I went ahead and 3D modeled it and printed one out. If anyone else should break this clip and have a 3D printer, I have attached the file. I would recommend using PETG or Nylon. PLA would most likely melt.
tw2 (10-01-2021)
The one I am looking for is ~21mm on one end and 14.5/15mm on the other. The part number you posed is close, but has a different orientation and bore sizes
2006 CLS55 AMG, 2005 SLK 350 AMG
14mm part # 123 995 02 65
19mm part # 110 995 01 65
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
If you do the 3D printing thing, I have used Shapeways before. One of my cars had a broken tab holding the seatback cover on. A work buddy measured and made a model from the other one which wasn't broken and I sent the file to Shapeways. $12,xx, filed it a bit, and epoxied it in. That was 3.5 years ago and it's holding up just fine.
kevm14 (09-30-2021)
The only other I find is a snap together like you show with 14mm one one and 19mm on the other. Since those are two different items (and separate part numbers) it suggest MB has differenet size options that can be snapped together to get the sizing you need. But, those are not shown for the E55 (211.076) model.
Odd there is no listing for the parts on an E55. It looks like it was there from new. I do not think it was added after the car was built. Hopefully my printed part will hold up.
