boost breaking up, hard jerking
I thought the bearing was bad so I replaced it and it’s still is acting funny, when I step on the gas it pulls for a second and then revs high and jerks not sure what the problem is now. Maybe the magnet? Please help
Based on your limited description, it sounds more like a slipping transmission than a supercharger problem.
I agree, supercharger not engaging will not cause revs to climb any faster, should still be a smooth sweep just with a lot less power. If revs are jumping around you've got other issues than the supercharger. First step you need a proper Mercedes diagnostic computer, not OBD2, and pull any codes from the ECM and TCU.
