No warm/hot air?
Thanks,
Chris
Thanks,
Chris
For heating there are two main components you should confirm are functioing. A circulation pump and a control valve. For the control valve there is one hot engine coolant hose going in and two that comes out. Check you have warm/hot going in and warm/hot coming out when set on a high interior heat setting. The attachement is the part view of the under hood layout. Item 30 is the control valve and item 300 is the pump. There are other things that can cause your issue, but these are the most likely suspects.
