E55 fuel surge tank thoughts/opinions
Old Nov 28, 2021 | 10:50 AM
Bay510E55's Avatar
E55 AMG
I am currently in the process of gathering information and doing research on how to best prepare my car for E85. One idea is to utilize a fuel sure tank from radium or deatschwerks using 2 walbro 450 fuel pumps(p/n f90000274) and have the factory pumps maintain the fuel level in the surge tank while the walbro pumps supply the needed pressure and have the return line from the fpr back to the surge tank and a over flow line from the surge tank back to either the passenger or driver side of the fuel hat. Tell me what you guys think and if this is a viable setup.
Old Nov 28, 2021 | 11:41 AM
SICAMG's Avatar
2005 e55 AMG
That sounds like an enormous amount of work with no gain and parts taking up space that is unneeded.
The basics.....Two 450 Walbros, all 3/8 lines internal of the tank, #8 line to the front, #6 return, and a Radium valve to feed the other side of the tank since you have removed all factory fuel tank fuel balancing.
Old Nov 28, 2021 | 02:28 PM
Bay510E55's Avatar
E55 AMG
which side should the return line enter back into the fuel tank?
Old Nov 28, 2021 | 03:41 PM
SICAMG's Avatar
2005 e55 AMG
Either side. Mine is on the driver side on top near the filter housing cover.
Old Nov 28, 2021 | 03:51 PM
Bay510E55's Avatar
E55 AMG
lik on the fuel hat or on the actual fuel tank?
Old Nov 28, 2021 | 05:36 PM
SICAMG's Avatar
2005 e55 AMG
Fuel tank.
Your going to be in deep with this project and need to plan it out well or you will have problems.
Look up "Walbro 450 PUMPS"on this forum and do some research. I have done a complete system as well.
Old Nov 28, 2021 | 08:26 PM
Bay510E55's Avatar
E55 AMG
Fuel tank.
Your going to be in deep with this project and need to plsn it out well or you will have problems.
Thanks for your help!
