Car having a hard time starting in a specific place
Old Dec 7, 2021 | 03:12 PM
TrippiesRevenge's Avatar
2004 S55 AMG
Question Car having a hard time starting in a specific place
Hello everyone I have an 2004 E55 with about 101k miles . The car is having this really weird problem where it has a hard time starting when inside a parking garage, Even in the mornings when the car is entirely cold it never has this issue. Cars parked from 7AM in the morning till 2PM in the afternoon inside a multiple story parking garage, i park on the third floor if that's of any importance. AT first the car cranks for a solid 4-6 seconds and then it barely starts, I can hear a few gurgles from the engine barely starting up and then it dies. when i take out the key and put it back in to try again the car fires right up. I drive it everywhere at all times and it NEVER does this at any other place other than that parking garage. any help would be appreciated thanks!
Old Dec 7, 2021 | 05:17 PM
MJBelcher500's Avatar
2006 E55
You really need to look up the DTCs with a proper scanner. Location should not have anything to do with why the car will not start. It could be a crank position sensor or a fuel pump problem. Without knowing what codes are being set it is just a guess at this point. Is the CEL on?
Old Dec 8, 2021 | 01:04 PM
cdk4219's Avatar
95 SL600
Could be the spark plug wires or cracked coils. Is it moist in this structure?
Old Dec 14, 2021 | 09:20 PM
2004 S55 AMG
I finally figured it out i think. i just have to leave the key in the igniton for a little longer than i normally would and it starts no problem i guess im at an incline that i cant notice but yes i live in florida so its quite moist anywhere
Old Dec 15, 2021 | 04:06 AM
equitiesguy's Avatar
Mercedes CLS 55 AMG
The starter is beginning to fail. I had weird situations like this myself for close to two years. Randomly, once every 2-3 months the car would do similar to what you described. Second time, would start up perfectly. It's the sign of a failing starter.
