Electric Trunk problem
Old Jan 19, 2022 | 02:59 PM
Janosch's Avatar
E63 W211
Hey guys!
I am new to this forum and reach out to you with a tricky problem:
My trunk opens electrically, yet it does not go down again fully. I have made a video here:
https://youtu.be/mvgjRQx5i4U
I have already checked the wiring and installed a new controlling unit but to no avail.
Does someone of you maybe habe a further idea?
Thanks in advance!
Old Jan 19, 2022 | 05:51 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Originally Posted by Janosch
Hey guys!
Thanks in advance!
If you have not already done so, you should do a deep search of this forum and the 219 (CLS55/63) forum as others have had this issue. Good luck and welcome.
Old Jan 20, 2022 | 01:54 PM
CQHall's Avatar
W222 AMG S63
I have this issue.
What has occasionally worked for me is to HOLD the close button as the trunk lowers as long as I can.
I don’t know if this is the proper training process, but it’s worked so far (this week).
Subsequent closes work with a single quick press of the button.
Old Jan 20, 2022 | 02:10 PM
MJBelcher500's Avatar
2006 E55
Hey guys!
Thanks in advance!
Have you tried using the button on the door panel to close the trunk? You need to hold it in the closed position until it fully closes.
Old Jan 30, 2022 | 03:18 AM
CQHall's Avatar
W222 AMG S63
Originally Posted by CQHall
I have this issue.
This is still successful for me.
I did have to retrain it after disconnecting the battery for some other work that I did on the car. But, after retraining once, it works fine.
