Motor Mount Help, Steering Rack Cover Removal
I reviewed many of the helpful threads here and the easiest way to do motor mounts seems to be removal of the steering rack support. These four bolts here. I have a few questions
- All 4 18mm bolts are unbelievably tight. Is this normal? I had to use a 42 inch breaker bar plus a cheater bar plus heat just to get them to move a little
- What is the torque on these bolts, when I need to put them back?
- I know the bottom two bolts have nuts on the other side I need to hold with a wrench. But it looks like the top two connect to the steering rack directly, and can be blasted off with an impact only, is this correct?
2006 CLS55 AMG, 2005 SLK 350 AMG
try this:
