Battery Warning Visit Workshop
I am wondering if anyone has any experience diagnosing these issues.
I do not have STAR diagnostic unfortunately (although I should have it), so I cannot be 100% sure but I thought I had found the root of the problem.
I have changed the Aux Battery Relay and the Aux battery but I still get the error. I get 14V to pin 30 of the relay so fuse 32 is good. I also get 14V to the rear battery so my alternator is functioning correctly. Continuity is good from positive of battery to pin 30 of relay.
How would I go about verifying the part that is highlighted in yellow?
I know where the polyswitch fuse is located but how do you verify its continuity? I cant seem to access the fuse part (its right next to the aux battery).
To what pins do the relay activation go to the BCM?
Should I bring my car to a garage where they have access to STAR diagnostic?
Thanks to anyone who can help me!
The circuit you've highlighted YLW is the control side of your AUX relay. It lets the BCM open/close the contact to connect AUX.
The parts you've replaced already were good wear item.
Now as to why AUX is still acting up...
1- Check BCM *GND* is good & clean.
2- CAN-B is the widest and serves the most modules.
Check its not disrupted by a bad module.
3- Is the BCM defective?
- Are you able to read it over Can-B?
- Open it to have look inside...
