Dyno'ed againg....
Old Oct 2, 2004 | 05:38 PM
elboricua's Avatar
2000 E55
Dyno'ed againg....
OK I dyno'ed my w210 e55 againg, this was a diff dyno the kind you back your vehicle to some rolls on the floor, but the results were the same 257hp and 269tq I am very dissapointed, the guy said my fuel air ratio was way too lean, the leanest he has ever seen, it was 16.3 to 1 im not to familiar with MB stuff so im asking for any advice, I dyno the car with K&N filters and without it was 250hp without and 257 with. Should I take my car to MB? It feels real slow and weak so any suggestion?
Old Oct 2, 2004 | 06:02 PM
elboricua's Avatar
2000 E55
Hmmm i found an article thats might answer my own questions here it goes:
When it comes to fuel mileage and increased fuel efficiency, this ratio changes again. All new cars run at 14.7:1 air-fuel ratio at part throttle because this is the lowest emission point. But depending upon the engine, it's possible to run an engine at leaner mixtures like 16:1 or more at part throttle to gain mileage. The difficulty with this is that driveability and throttle response suffers at these ratios. Engine response is lazy and stumbles are commonplace. Each engine will be different, but there is fuel mileage to be gained by fine-tuning your carburetor. Don't be intimidated by these lean mixtures at part throttle. You won't burn the engine up since it is making very little horsepower at part throttle cruise--often less than 30 hp.
AND THATS WHAT IM MISSING 30HP. AND IM MAKING AROUND 24MPG.
HERES THE LINK http://www.carcraft.com/techarticles/116_0402_tune/
Old Oct 2, 2004 | 07:03 PM
elboricua's Avatar
2000 E55
i was reading a w211 runs 11 to 1 any help on how i can fix mines?
Old Oct 2, 2004 | 07:51 PM
JAYCL600's Avatar
new balance
Have you had your MAS replaced?
Old Oct 2, 2004 | 09:07 PM
elboricua's Avatar
2000 E55
i bought the car 1 month ago so i dont know, could that be the problem?
Old Oct 2, 2004 | 09:29 PM
JAYCL600's Avatar
new balance
We have all had them replaced...common problem with W210's.
Jason
Old Oct 3, 2004 | 11:22 AM
Happy2th's Avatar
2004 E55
What does "againg" mean?
I thought it was a spelling error in your title, but you spelled it the same way in your post also.
Old Oct 3, 2004 | 01:16 PM
JAYCL600's Avatar
new balance
I think he meant "again"
Old Oct 3, 2004 | 07:47 PM
elboricua's Avatar
2000 E55
My bad english is my second language.
Old Oct 3, 2004 | 11:22 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Yep, probably a bad Mass Air Flow meter. MAF.
Old Feb 12, 2005 | 05:46 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
E55 engine in C43
Here is mine and the car is running Superlean,I'm not surprised!:[img=http://img109.exs.cx/img109/2779/scan3jm.th.jpg]
Well the soft ware upgrade is next week and shows me that the stck C43 software file has my car running lean as hell.thank God the motor has not blown up.It's not pinging but we know the timing is being pulled bac some to protect the motor.MB and Bosch engineering on top of things again. It's not compensating.We will be inputing a modded E55 file into the ECU chip.
270whp and 286.71 ftlbs.tq in the high 14's a/f is much too lean.We will have the a/f in the low to mid 13's after the flash.Stck NA E55 runs pig rich at mid to high 11's A/F.There is one run where my car actually hits 15.6 ouch!Car should theoretically pick up at least 20-40whp and more tq.I will probably change the air mass as well.I can imagine what the car will run like after the mapping etc.It's no slouch as of now but we know it will run better. Thanx to George and Brian of ICS performance Connecticut.www.icsperformance.com.
Old Feb 13, 2005 | 01:34 AM
RossN's Avatar
2002 ML55, 2006 C6 Z06
16.3 to 1 !!!!! Geez Uzzz That is way lean. You need to have that looked at promptly. And don't do any high rev action til you do. If it wasn't for your ECU "protecting your engine", detonation might have blown blown a hole in one of your pistons already.
Old Feb 13, 2005 | 01:49 AM
RossN's Avatar
For power it is around 12:1 or 12.5:1, for full throttle FI (forced induction) engine like the E55 you could even see 11:1 TO 11.5:1 (extra fuel cools the combustion chamber avoiding detonation) to add cooling in the upper rpm range since the cooling system is aready weak to begin with in keeping AirTemps rock steady.
Running at WOT (wide open throttle) as on a dyno and seeing 16:1+ is dangerous and short lived at extended rpm.
Old Feb 13, 2005 | 02:18 AM
speedybenz's Avatar
AMG C43, 1999
Do you know if your engine ECU went into Open Mode and did not stay in the Closed Loop mode during the Dyno Runs. That is very lean for wide open throttle. You can also check the duty cycle of your injectors to make sure they are not running over about 80%
But yes, if you are running these Air/Fuel ratios when the ECU is in Open Loop then you are going to see some pretty nice increases in Hp and torque when you get the A/F mixtures around 12.8:1 or so.
Jeff
Old Feb 14, 2005 | 06:18 PM
MoTo's Avatar
98 C55
Carl,
Keep me updated on this issue.
Old Mar 27, 2005 | 07:51 AM
ProjectC55's Avatar
Originally Posted by MoTo
Carl,
I finally purchased and placed a new AMG computer in the C43 to accomodate the 5.5L motor.Had it programmed by my friends Star diag equipment,Pulled the E55 files out of the AMG chip(C43 and 99 E55 files stored in chip) and voila! What a hell of a difference.Car now thinks and runs like an E55.The top end and mid range torque is tremendous.The lean condition caused by using the original ECU(C43 married)is virtually GONE.I also had to replace the C43 traction control module to a 99 E55 traction control module.The ESP/ABS lights are now out because the programmed (E55 file)see's the module now.I can't even describe the difference.Man what a car now.Leaving the hole with the car in D3 and traction control off is insane.The car gives such a rush it's incredible.I hope to re dyno the car in 2 weeks just to see what#'s I now have.After this will definitely be the Powerchip upgrade.
Old Apr 15, 2005 | 06:38 AM
ProjectC55's Avatar
We found out yesterday that this was definitely the source tomy low dyno #'s. Here's my post:https://mbworld.org/forums/c32-amg-c55-amg-w203/105063-changed-airmass-car-beast-w202-c43-55-a.html
Old Apr 15, 2005 | 09:57 AM
BlownV8's Avatar
Glad I could help.
Old Apr 15, 2005 | 06:10 PM
ProjectC55's Avatar
Glad I could help.
you're the man!!
