Home Link Rear View Mirror
Old Aug 8, 2022 | 03:38 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
My E55 doesn't have the homelink garage door opener buttons on the bottom of my mirror. Can you just buy a used mirror that has that feature and it will be plug and play? Can I just take apart the mirror part and swap the parts internally and snap on the Homelink portion of the mirror or do I have to replace the whole mirror assembly?
R.K.
Old Aug 8, 2022 | 05:14 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
I purchased a new Homelink mirror and moved it between cars. As long as the existing mirror bracket is glued to the windshield, you should be able to make it work. If the existing mirror is "built in" to a housing surround you might have trouble. Of course you need power. I was able to run the power wire by tucking it into the headliner, and then prying off the "A" pillar plastic trim, remembering that there's like an air bag in there. Once I did that, I ran the power wire to a fuse that was "switched" i.e. off when the key was off. There are installation videos on youtube that you can view ahead of time to gauge the viability of success.
Old Aug 9, 2022 | 10:16 AM
CQHall's Avatar
W222 AMG S63
I have Homelink mirror as part of my options package and I cannot get it to work with my modern garage door opener...even with that connector thingy.
It's frustrating as hell. Any programming tips would be appreciated.
