Noise coming from front of engine?
I’m hearing a loud noise coming from the front of the engine on my CLS55. Car only has 60,600 miles. Doesn’t sound internal to the engine. Doesn’t sound like its anything from the valvetrain. Anyone know what it could be? I rarely drive the car hard and do mostly highway driving. Oil level is fine and oil temp seems to be normal. Car still pulls like normal. Sounds like it’s coming from the pulley.
Link to a video of the problem I’m having:
https://youtube.com/shorts/Evxfl0NPotY?feature=share
2005 CLS55 AMG W219 C219
I think so too
While you are in there:
-Replace the supercharger idler pulley
![](https://lh3.googleusercontent.com/pw/AL9nZEVUa9exvYMHAThm-c_r8Ot_HDkZWKYkkbtpY5hum_5ZDOyimcDX-cmtH6ZXDeOdbtxrbfBakk7gRoVFNPXAWCyTIPqu-Tk4PSRDzR_-WHHV-N3Zu36tQ2kIWXIhsu2gejD6zwlgla3PVi1aR2gL9W9l=w1024-h576-no?authuser=0)
-Replace the supercharger pulley bearing
![](https://lh3.googleusercontent.com/pw/AL9nZEX9H-LynnGZveMOUUEGwRXFUZE4lmwoCdjmB3BQiLB3JZVdEpCZab8dBfRUDhyS8I6SWkKf0HQZmOQTqJdPreU_ijieyFtdq1WTIDERPg2b_wx4ZS85ydrdDGmi969cBpeEywqdFWkBJyvcttOfAOX1=w1024-h576-no?authuser=0)
-Replace the supercharger oil (Mobil 1 Jet oil)
![](https://lh3.googleusercontent.com/pw/AL9nZEVo9--w-k7GC8sR_it9-TPMNoxajDA0SMPg8JuQKk6qu4KcMctoVfnw3fmId-BdesZk4X3qwGkzsdEH2rqP3QLns_xeWDM92qyWYjYEf0u3sXcY4vJZv8twf82ZwkCb6ElBom6nAm_-e0kXo7ORm-rR=w1024-h576-no?authuser=0)
It could also be the other bearings (from the serpentine belt route)
Diablo_CLS55 (10-07-2022)
2006 CLS55 AMG, 2005 SLK 350 AMG
nd-photo.nl (10-06-2022)
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
While you may be correct that it is a pulley, it is easy to use a section of heater hose to act as a stethoscope. One end to your ear and the other end moved around the area you think the noise is coming from. When the hose comes across the noise you will hear it clearly through the hose end. No guessing.
nd-photo.nl (10-08-2022)
Diablo_CLS55 (10-09-2022)
I heard that sound. 45 minutes later, my supercharger and accessory belts where in shreds creating havoc in the engine bay.
You should be able to take the tension off of the belts and remove them from one pulley in the system, then wiggle the pulleys to see if there's play.
Here are two threads regarding my adventure:
nd-photo.nl (10-09-2022)
