Need help removing the rear dome light!!!
Old Oct 20, 2022 | 08:43 PM
DevilDog81's Avatar
Veteran: Marine Corps
E63
I'm trying to switch the bulbs for the rear map/dome light on my w211 E63 with panoramic sunroof without breaking them!!
How do you removed them?
Old Oct 21, 2022 | 12:38 AM
black06c230's Avatar
mgLipGD
pry on the long flat edge side. You should be able to see a tab area to press in from the side and then pull down. Small flat head or a trim pick tool is best. Also be careful as the ambient light in side is connected with a ribbon cable.
Old Oct 23, 2022 | 11:42 AM
DevilDog81's Avatar
E63
Thanks so much. Followed your instructions and it did the trick!!!
