Coolant Question / Issue - Which to use? How much?
Hello all!
I had to replace my thermostat as it was stuck in the open position (one step better than stuck in the closed position!). I did the replacement and now I am attempting to refill the coolant I lost and thereafter bleed the system. I lost a fair amount of coolant in the process, and frankly I don't know how much.
I bought my thermostat kit from FCP Euro that included a bottle of Merc. recommended/verified coolant (Link: https://www.fcpeuro.com/products/mer...des-1562030475).
I know that last time my E63 was in for a service at my independent shop they topped my reservoir tank off with "Anti-Freeze GO-5" to which I assume is Valvoline Zerex G-05.
My questions are: (1) Should I use the Merc. recommended fluid (after diluting) to again, top off my tank. or (2) should I attempt to use the same coolant as used by my servicing independent shop? (3) Something else? and finally, (4) How do I know how much coolant my tank needs? This seems like a surprisingly simple question but I have not found a good answer. Just fill to the seam in the reservoir tank?
Thank you in advance!
2006 CLS55 AMG, 2005 SLK 350 AMG
Hello all!
GR_E63 (11-22-2022)
Received 3,925 Likes
2017 GLE350 4MATIC
Go to the operating fluids website. It takes some patience, an patience will be rewarded.
Fill to full and let the system burp a few times. Distilled water in small quantities is an acceptable crutch.
GR_E63 (11-22-2022)
