Replacing AC Compressor pulley
Has anyone replaced the AC pulley/clutch while it's still installed and is it a pain ?
I found a new clutch+pulley on ebay for $60 and wondering what sort of fun I'm in for.
for.
https://www.youtube.com/watch?v=2pe2t3xESSY
Thanks !
I found this tool, which probably works too and is universal
https://www.amazon.com/dp/B004KEFCPU/
I got my old broken one off with vice grips and put the new one on by hand. The new tool wasn't here yet but I was curious if my compressor was still good or if I truly was lucky enough that it was just the pulley. So i put the belt on and started the car to see if the compressor worked. It worked.
When the special tool arrived and I tried to tighten down the pulley bolt, it was already tight.
So the tool is necessary to get the old one off, really. But mine had exploded so the tool was useless for that, which is why huge vice grips came in handy.
When checking my pulleys I hear a bit of a grinding sound coming from the AC. AC itself is working fine. Not sure if this noise is normal.
I was thinking to start simple by checking/replacing the pulley bearing.
- Does anyone have the number or specs of the bearing?
My parts shop has 2 sizes: outside diameter 52mm, inside 35mm. One has a height of 22mm the other 12mm. (compressor A0012301211, pulley A0002341312, MB W211, E320)
- I would be interested where to find the extractor tool in Europe.
I can find this, but I am not sure it would work?
