Code 0730 with Transmission slipping, limp mode and CEL
It started with an unusual 2-3 shift, like it was hanging on to 2nd gear and finally a slightly abrupt change to 3rd gear. Then slipping under full throttle from 60 & 70.
I did a drain and fill with new filter, replaced the connector and swapped out the MK Ultra TCU back to stock. It was fine for a few weeks till last night. Started slipping out of gear during normal city driving and finally went into limp mode with a CEL. I checked fluid level today, seems right, not red but not black either with a slight odor. Everything is dry underneath. Read and cleared code 0730 with torque app. Drove a mile or so and back to limp mode and CEL.
Some say transmission is shot, others say conductor plate, and some think valve body.
Anyone have a similar experience and fix?
'99 and '05 E55 AMG
If the transmission stays in limp mode until you clear the code that means there is an electrical fault with the transmission. If you put it on Star you can read all of the values of the solenoids and the pressures and the activation times for the clutch packs and the brake packs. It will most likely end up being a bad solenoid or a bad speed sensor on the conductor plate but do not discount worn friction plates on a clutch pack. A new clutch pack will have 0 to 1 each 20 millisecond pulses to engage the clutch pack. A worn clutch pack will have 15 or more 20 millisecond pulses to activate a clutch pack. That indicates the friction discs are worn out and the clutch pack needs to be rebuilt. Do not throw parts and money at the car until you can put it on a star diagnostic system and read all the values out of the transmission.
05-E55....
You have the same thought process as a lot of customers we have at the dealer have. " It only has XX miles and my other car had XXXX miles" ???
I have gotten transmission issues on vehicles with 25-50 miles or 100,000 miles, it's just something that happens with no rime or reason.
Hell my 98 Crown Vic has 255,000 miles and has been almost trouble free its whole life. Other cars in the household....not so much.
Sucks but it happens.
No. Really I don't. That's why I'm asking here. And others think it may not need to be but it seems I won't know without a Star diagnostic.
If it does is it something any transmission shop, i.e. Aamco can do or do I need a specialist?
2004 Crossfire (w/M113K), 2008 Crossfire (w/M156), 2008 CL63, 2008 ML63, 2018 AMG GT
For a general rebuild, yes. This is an extremely common transmission, shared not just on MBs, but Chryslers and other makes.
05-E55 (12-14-2022)
05-E55 (12-15-2022)
Anyone have experience with Sun Valley Transmission? They offer rebuilt ones for $2500 which is less than any quote local. Also Autohubshop on eBay advertising remanufactured for about the same price.
05-E55 (02-08-2023)
