Camshaft kleemann in m113k
hello friends. I want to know the feedback from users of kleemann camshafts. I bought new shafts. tell me how the power of my w211 e55 will change? today I use pulleys 175 and 77 and good cooling. my travel time is 100-200? does anyone have experience with these shafts? do you feel an increase in power?
W211 E220, W211 E55, W219 CLS 500
Hi, I use Kleemann cams in my car along with mid tube headers, 80mm throttle body, and a stock pulley which has been milled to 88mm. My lower crank pulley is stock. I fiddled with the cooling and stuffed in 3 heat exchangers and a Pierburg CWA100. Depending on ambient temps my car does 100-200 kph in 7.1 to 7.7s.
Mist noticeable difference with these cams is, they make a tad less torque than the stock ones, but the power keeps going up till 6500rpm. The stock cams drop power after 6100 rpm roughly. Last summer I was on the dyno with some other 55. One guy had a similar mod list like mine and I've attached both power curves.
Stock cams
Kleemann cams
Stock cams
Kleemann cams
Stock cams
Kleemann cams
Stock cams
Kleemann cams
Top dyno was from a different car with stock cams. Mine is the bottom picture with 572hp. The other car had more HP due to running more boost. He had a 172mm crank pulley and stock upper pulley. Mine had a stock bottom pulley and 88mm upper pulley.
You can't compare the numbers between the two cars, but the power curve itself.
UncleBenz55 (03-05-2023)
