Gearbox cooler relocation kit?
Has anyone developed a simple relocation kit yet?
Or at least a new kit that replaces the crossflow with something somewhere else?
Ive seen a few other people make some custom stuff but not really sure how to get all the fittings to marry.
Also does anyone know how high the pressure gets in the transmission cooling circuit? Trying to figure out if its a simple slip fit with band clamps or if I need to incorporate threaded A/N fittings etc.
What do you mean by Gearbox cooler underneath the heat exchanger? As far as i know coolant radiator shares bottom part with transmission cooler. Underneath the heat exchanger is engine oil cooler.
Correct me please if i am wrong.
If you are talking about small oil cooler, then you can simply install copper pipe like @UncleBenz55 did in his thread.
Part number from mercedes. A2115010201
https://www.ecstuning.com/b-genuine-...er/2115010201/
Are we talking about same part?
https://mbparts.mbusa.com/oem-parts/...ler-2115010201
