Transmission replacement 07 e63
Thanks in advance everyone
As I had suspected, it turned out STAR/Xentry pointed to the Speed Sensor(Y3/8n2) with codes (2767 & 2768) located directly on the TCU above the Valve Body itself Inside the Transmission Housing (unlike E55 or even later model E63's where they are located under the Passenger Floor). I ended up Removing the Tranny myself, just as I had done a year or so ago during my marathon 2nd build of the Rear End where I split the Valve Plates and cleaned the Valve Body (I posted this procedure in detail NOT Referenced in WIS). I sent my TCU to Circuit Board Medics (CBM) and was surprised at just how fast the turnaround was! I haven't had an issue since. This is the only way you can go without facing the reality that one must otherwise take their inoperable car to Mercedes to have them use their "MB Connected" Star Xentry to Reprogram the owners' "New/other" TCU/Transmssion.
So bottom line, if your Tranny is toast due to the gearing, one can avoid the above mentioned requirement by finding an "indy" Trans specialist to rebuild your own Tranny. While doing this, spend the $$ to have CBM "Future Proof" your TCU (assuming it's located above the Valve Body) and you thus avoid having to go to Mercedes and pay to have them do this "$ervice" for you, that is, if they will do it for you?!?!. I'm not sure what the status is on being able to purchase new Tranny's through Mercedes, but as long as it's possible, surely their recommendations would lean that way! Can you say $10k+ including install!!!
I had initially decided, there on the side of the road, to have Renntech do their Tranny Upgrade ($3k+) which they promote online. So, off the car went to RennTech. However, as pertains to the TCU, I only found out the next day that they don't do that repair so it would have cost me $2350 +4 hrs @ $175 p/hr to replace the "Body/Control Unit" (ie-Valve Body/TCU), but when they told me their MB Xentry was having "issues" and that they could NOT reprogram any replacement units at any time, I had to get my car towed back home and although I didn't get buffed out with upgraded Gearing, I did save some major $$ DIY! I think anyone would agree, It would have made no sense to pay them to the above without their being able to do the necessary programming! But in their mind, they thought they had me, that is until I told them I could get the TCU Repaired myself!! And I'm a happier man today for it!!!!
