M113K engine number decode
Old Dec 31, 2023 | 04:21 PM
OzE55AMG's Avatar
E55 W211
Hi All,
I there a way to check the original vehicle VIN that a given M113k motor came from originally?
Old Jan 1, 2024 | 06:42 AM
Abby87426's Avatar
2006 E55 AMG 2002 C32 AMG (sold)
You go to https://www.lastvin.com/ and enter your VIN number and it lists your engine serial number.
Old Jan 1, 2024 | 05:31 PM
OzE55AMG's Avatar
E55 W211
Thank you.
I have downloaded the data card for MY car.
Problem is, the engine number on the data card does not match the engine number currently registered in the car.
I would like to find out which car this replaced engine came out of........
Hence......how do I run the 'new' engine number to track the previous VIN number??
Old Jan 2, 2024 | 05:18 AM
Abby87426's Avatar
Sorry, I’m sure someone might know to find which car this came out of by searching a database but I don’t.
Old Jan 2, 2024 | 05:20 AM
OzE55AMG's Avatar
E55 W211
Thank you for your kind thoughts.
Old Jan 4, 2024 | 06:02 PM
SMOKEY300's Avatar
S211 E55 AMG, W205 C250
There is no public way to reverse search the engine number to find the VIN.
Have you got any service history on the car? Perhaps contact the last MB dealer that serviced the car, and appeal to their kind nature and see if they can do a database search for the engine number.
I assume you're trying to find out of the engine in your car has less than the current odometer - in which case I would assume the answer is 'yes'.
Old Jan 4, 2024 | 09:53 PM
OzE55AMG's Avatar
E55 W211
Many Thanks Smokey,
Essentially we have zero info on when the motor was changed out, let alone why.......although it HAS been in there for at least the last 4 years.
Main fear is.......Car shows 180,000 kms, but.........what if the engine had already done 250,000 kms, and was put in this car 100,000kms ago???
That said.....the rest of the car (and the engine, etc) are super, super, super clean, in a "taken care of, not restored" looking way....
Old Jan 4, 2024 | 10:53 PM
SMOKEY300's Avatar
An independent mechanic with STAR can read the modules. There will be trace recording in the EIS and ECU, and you can also download the service records.
However, the reason for the engine being swapped out in the first place will remain a mystery unless it was done under warranty at MB, in which case, I'd still contact the dealer to see if they can pull any records.
But to be honest, if the car is on 180kms - and the is healthy - it's probably not worth worrying about. I understand the 'peace of mind' factor, but I'd take a well maintained m113k at 250km over a neglected one at 85km.
Old Jan 12, 2024 | 04:23 AM
HazelMetz's Avatar
tesla
Any update?
Spoiler
Old Jan 12, 2024 | 06:40 AM
OzE55AMG's Avatar
E55 W211
Update is this.......
I bought the car, Roadworthiness test & registration transfer, etc.
in the first 48 hrs.....just sitting in the car park with the motor running for 5 minutes........and the front end just dropped.....and stayed down.....
I was able to buy an aftermarket NEW strut locally, got it all installed today, and we're all good.
Worryingly.....the airstrut that failed was a known brand refurbished original.......date stamped March 2023.........
