Fluid Leak
yellowish clear and viscous. probably either engine oil or transmission fluid.
in the dealer today for diagnosis.
anyone else experienced anything like this?
Thanks cte430
Advice to all - check the parking spot periodically. If I hadnt looked at the empty garage floor, I'd never have known.
Edit: It was the E320 with hard shifts from 1st to 2nd.
Thanks cte430
My 04 E55 had the same problem as well. It was leaking a reddish oil. The dealer replaced the an o-ring seal in the tranny for a fix. While the car was there, they also did the brake recall on my car. Other than those two problems, my E55 is much much more reliable than my old 01 S55.
Raymond
Raymond
ANyone know?
The E320 and E55 both not only had hard shifts when cold, but also delayed. The replaced some stuff inside the tranny and reprogammed it to factory specs. This is not normal for sure.
I just took my 04 E55 in for a leak, they replaced the transmission plug, topped it off, etc. Now, a week later, there's a (much smaller) puddle still under the car. I'm HOPING they just didn't clean it off well. (Hasn't been driven much, we're in a snow watch here). Anyone else have this happen? A follow up leak after a transmission fix?
Mine just started after 7,000 miles and 1 year of ownership. A known problem among all MB classes. Somewhat disappointed that our $90K sedans have this problem. Will be taken it to the dealer first thing Monday and waiting (takes about 30 minutes) for them to replace the seal.
