2007 e63 amg head bolts
2007 e63 amg
Hello I recently purchased a 2007 e63 amg
I was wondering what some of you folks changed when doing the headbolts
I’m located in ct if anyone knows good shops in ct Ma or ny thank you
2004 Crossfire (w/M113K), 2008 Crossfire (w/M156), 2008 CL63, 2008 ML63, 2018 AMG GT
I just did this with two different engines. New valve cover and cam phaser block gaskets are highly recommended. I also changed spark plugs, as everything was apart. The thing you'll really need to look at are the cams themselves and the cam followers/lifers/lash adjusters/buckets/whatever your terminology is. On older engines, it is quite common to find them to be worn. I had one engine where it all looked great, and another with fewer miles, but 5 cam followers showing undesirable wear patterns. Cams were fine in both engines.
I broke the cam phaser bolts loose before I took it all apart on one, and on the other I made alignment marks on the cam and front cam caps to line it up. In both cases, I still wound up needing the cam timing fixture. Also, I use a letter & number stamp set, and I stamp all of my cam caps for position number and labeled "I" and "E" for intake and exhaust. I also use this for orientation. There are other ways of telling, but numbering (from front main cap) 1 through 5 makes it dead simple.
Lastly, you will make a mess with this. Oil will dump onto the exhaust, and all down the front of the engine. I put rags where I could to sop up what I knew would leak. You'll need a lot of brake cleaner to get it all off the exhaust, and control the burning oil smoke.
mbwillgrubs (05-16-2024)
