E55Amg Low boost
With this mods:
76mm sc pulley
Long Tube Headers
And secondary Heat Exchanger and Primary XL Heat Exchanger
im only hiting 12.57 psi on 3rd gear and 13 psi on 4th gear its my boost okay or where its the problem
im doubting on the obdII cuz i measured the boost on 2 diesel cars and they both hit 22 psi one its bone stock and the other one its 450hp i have used the torque pro app
So its my boost okay if not where its the issue and its not to hot here 22 degre celsius and 18m above sea level please help
im not saying that i have to make the same boost as them but i think that its not measuring right
because why the 2 diesel cars made the same amount of boost when one was stock and the other was 450hp diesel car in the dyno that diesel car it made 34.8 psi
so all im asking its my boost level okay on my e55 with my current setup or it should be higher or my obdII its not reading right
Also @BlownV8 is right, the longtubes will cause a reduction in boost but will make more power. If you do the Needswings intake plenums, you will also lower boost, but will make more power as it becomes more efficient.
[edit]
Boost does not equal a certain horsepower...
My boost at sea level in 50 degree air peaks at 16.5lbs and will drop to 14.5 or so at red line.
A hot day loses 1 lb across the board.
At the track it will peak at 15 and drop to 13 but that's also at 1,200 elevation. Even my Dyno day was only 12.8 at red line and 1k elevation.
Clearly the blower can not keep up with engine air flow and why it will drop in the top rpm curve.
