Random no-boot radio + battery drain
Old Aug 7, 2024 | 07:49 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
2005 E55.
Randomly, my radio stop working. Won't even boot. Just shows the AMG logo for a while then goes black. Then, when the car sits overnight, the battery is drained and it won't start.
Oddly, if I disconnect the battery to charge it, then reconnect, the issue goes away and the radio works fine. You can see how this makes it very difficult to pull codes... Any clues?
Old Aug 7, 2024 | 09:16 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
There is a "soft" reboot of COMMAND that requires holding down one or two buttons on the radio for at least 19 seconds (IIRC) and a "hard" reboot that requires pulling two fuses in the driver's side dashboard fuse box. That will reset your radio and might stop the battery drain if it is COMMAND causing the problem.
I had to use the "hard" reset one time in the ten years I have owned the car. Advanced search should find the procedure. That's how I found it years ago. I didn't have the battery drain but the failure to boot symptom sounds the same.
If you can't find it, let us know and I'll dig in my maintenance files to find it. Please post your results for others.
Old Aug 8, 2024 | 05:04 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Most likely not the Command, but more likely the AGW (Audio Gateway) module in the back...There should be a fuse for that in the rear SAM, pull it and see if you still have battery drain.
Old Aug 8, 2024 | 06:13 AM
ls1_mast's Avatar
w220 S55 AMG 2004
had a similar experience before with the w221 s550 while driving suddenly the command stops working then restarts by its self then not working ... the reason for me was the alternator is about to die... the alternator was going on and off while driving and that caused the issue ...
my advice test you alternator to see if it doesn't stop working randomly while driving... to do that , start your car and let it idle for 10 minutes ( for the alternator to get hot ) then disconnect the battery cables and let the car idle for 10 or 15 minutes ... if it runs fine then your alternator is fine... if it worked for a few minutes then shutdown then it means the alternator stopped at that point and there is no battery to compensate for the drop in volt... and you will then need to replace your alternator.
Old Aug 8, 2024 | 09:17 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
A day late and a dollar short but here are the three fuses of interest for your model year.. Apologies for the poor scans.
Driver's side dashboard fuses #26 (CDC) and #28 (COMMAND):
Rear SAM #6 (AGW).
Old Aug 9, 2024 | 08:11 AM
Sulaco's Avatar
Thanks so much! Will pull these and check for drain the next time it happens
Old Aug 14, 2024 | 06:03 AM
JacobBrown's Avatar
ford mustang 1969
Spoiler
https://www.youtube.com/watch?v=ZEbu3ndR7kE
Thanks for the video, that helps a lot.
Old Aug 14, 2024 | 10:17 AM
You are very much welcome! There is a lot to find on Youtube with regards to battery drain
Old Oct 4, 2024 | 09:14 AM
Sulaco's Avatar
welp you guys were correct, it's the audio gateway
I've been able to skate by just pulling the fuse and putting it back in and the problem would go away for days/weeks.
but now the problem has gotten so bad the audio gateway fan will just kick on at night with the car off and drain the battery, so I have to keep the fuse pulled entirely
Anyone know of a fix? I'm handy with a soldering iron so I'd rather not just buy a new AGW
Old Oct 5, 2024 | 01:35 PM
Reroute the cable to a switched 12v?
Old Oct 5, 2024 | 10:17 PM
Sulaco's Avatar
I'd be all about it, but when the AGW glitches I lose the entire head unit; no audio
Old May 17, 2025 | 05:58 PM
slimm6112's Avatar
w166
2007 s550 command does not work and battery drains.
I'm having this exact same issue with my 2007 S550 W221. The battery is draining way too much when not in use and the command center does
not turn on, it only shows the Mercedes emblem. Did anyone figure out exactly what was wrong with their car?? Let me know please.
Old May 17, 2025 | 06:10 PM
slimm6112's Avatar
w166
probably the module
Old May 18, 2025 | 06:53 PM
Sulaco's Avatar
audio gateway, pulled one from a junkyard for $17 and swapped them out. fixed.
Old May 18, 2025 | 09:22 PM
slimm6112's Avatar
w166
Audio Gateway Module?
Old May 19, 2025 | 10:16 PM
Sulaco's Avatar
correct
trunk, left side, above wheel well
Old May 19, 2025 | 11:45 PM
slimm6112's Avatar
w166
Thank you!!
