Transmission service
Old Oct 7, 2024 | 11:17 PM
Fountain35's Avatar
The E55 is going in for a transmission service. What fluid are recommended, anything new and improved and if memory serves me there is a filter change.
Anything else?
Old Oct 8, 2024 | 07:32 AM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Anything else?
The service should include the replacement of the bushing (elelctrical connector) to mitigate the wicking of transmission fluid into the wiring harness.
Old Oct 8, 2024 | 07:39 AM
SICAMG's Avatar
2005 e55 AMG
Yep comes in a kit.
I always use Red line D4 fluid but maybe the factory fluid would be best for you and piece of mind since that is what Mercedes calls for.
Old Oct 8, 2024 | 01:32 PM
ArmoE55's Avatar
2006 E55
Chris,
Assuming you're taking to a dealer for service? If so, they have a kit that has everything needs for replacement. I don't go to the dealer anymore, for years, and use an Indy, but when I did go - they always used a kit that had the filter, oil etc.
Also, and this is just me, I personally only use MB for fluids like this - just a mental thing and I trust what AMG says to use. Having said that, tons of people use aftermarket/other products with great success.
Car will feel a lot better after this service, it was night and day for me when I crossed 55K miles and got the service done.
Old Oct 10, 2024 | 06:49 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Are you going for standard service (fluid + filter) or do you want an overhaul? Things to consider:
- O-rings for all solenoids
- New TCC lockup solenoid
- Sonnax overlap valve kit
- Sonnax TCC damper
- Solenoid filters (2x)
- Solenoid strainers (2x)
Old Oct 10, 2024 | 08:15 AM
SICAMG's Avatar
2005 e55 AMG
Nd don't forget the Nitrous kit as well....it will help with the shfts !!! LOL
