E55 Map reading peaking at 21 psi.
Old May 31, 2025 | 03:08 AM
slowwe55's Avatar
2005 E55
Recently I tried to monitor my Boost as I thought I was getting belt slip, on full throttle pulls the MAP sensor would peak at 21 psi, which I believe is only 6 psi of boost. Still on stock pulleys so I decided to order a belt wrap kit and a new belt and when I did another pull it still only peaked at 21 psi. At first I thought it could be a boost leak but I don’t think it would perfectly peak at 21 every time. Could this be a faulty sensor or something really wrong.
Old May 31, 2025 | 11:50 AM
SICAMG's Avatar
2005 e55 AMG
Why do you think you should be peaking at 21lbs?
What pulleys do you have?
Old May 31, 2025 | 12:53 PM
slowwe55's Avatar
2005 E55
I’m still on stock pulleys. Ive read in other forums that boost is the MAP minus atmospheric pressure. If I’m peaking at 21 then I’m really only getting 6 psi of boost.
Old May 31, 2025 | 01:28 PM
SICAMG's Avatar
2005 e55 AMG
OK your wording was a little confusing.
Why don't you get a boost gauge to see for sure what your boost is and then go from there. Also stock boost is around 10-11lb's if I remember correctly.
