MAP changes levels ?!?
Old Dec 28, 2025 | 10:29 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Weird MAP data behaviour - start car and range is from -11Psi to + 15
Refuel and the stream changes from -3 to +21 … the change happens when I open the fuel cap.
Possible the evap opens up reducing vacuum? But then why is boost so much higher? Running 180mm crank pulley.
charcoal canister checked out ok. In my model I dont have a canister check valve only the valve thats in the engine bay. Its the almost cylindrical canister not the odd shaped version.
Old Dec 29, 2025 | 03:00 PM
fazxs's Avatar
2005 E55 AMG Wagon
Opening your fuel cap immediately changes your MAP readings confirms that your intake manifold is physically "linked" to the atmosphere via the fuel tank when it shouldn't be - it could be the purge valve that is stuck open. You have ruled out the charcoal canister which again points to the purge valve.
