E63 M156 / Intake Y pipe difference.
Would it be an upgrade to switch to the newer style?
Thanks!
Early intake
Late intake
This system has been part of the vehicle since its production, ensuring optimal performance without the need for modification.
Given its proven reliability over the years, there is no reason to replace the existing intake setup.
The earlier ones are notably larger / flow more air. On those cars, there is a metal vacuum canister bolted to the side of the engine instead of the plastic one that's integrated into the newer design.
Hard to find good info on what it's there for, but the most interesting explanation I came across was that it was related to the actuation of the plastic flaps inside the intake manifold.
I'm going to install the larger Y-Pipe this Spring (found a vacuum reservoir for a different platform that might fit in the engine bay).
Not intentionally, mind you, just the ones I'm finding that could fit in the engine bay seem to be larger than the factory one.
In practice, what I'm trying to determine here is whether increasing flow via ROW air box lids and the larger Y would be impacted (in any way) with a larger resonator.
