I had them in 20 inch and they look great. I had to buy 3 sets over a year though because they continued to crack. I spoke to Niche and they offered no help other than "that should not happen". I ended up removing them and getting a different set and going with 19's. The 20's look great but the rubber band tires kill them. I literally drove 5 miles and one cracked...with the rep in the car! Only way I was able to get a different set...
^ thanks bro. but hey ...are these the same as yours ??? I do notice the mine lip has a little outter edge and yours don't and yours is also more aggressive in the front ... teach me.
yeah they're the same but mine had the rolled step lip!
what's your offset in the front?
so my set is also step lip but without the rolled edge ?
they are 597r right ?
no idea but it doesn't fit flush and ill need to add spacers to make it nice for sure.... the rears are maxed out tho cant even put any bigger than 275s...
ill get them tomorrow hopefully. does it have the offset stamped in the back?
They're 547 step lip! I think you going to need 12mm spacers in the front. Hre usually have the offset stamped in the back
thats funny- i was at a sleezy rim ship while tagging along with a friend & the owner started telling me about Niche rims and how they are infinitely stronger than Vossens while being much cheaper & he has never seen a Niche rim crack haha ... at least Vossen honors there warranty...
how do you avoid the front wheel hitting the fenders while driving and turning?
Mine is doing that now with coilovers installed
Hey sorry for the late reply.. I haven't been on the board for quite some time.. Anyways, after driving around with those iForged wheels and tire combination, I had to pick up a thinner set of tires for them. I had to run stretched tires so that it wouldn't rub when turning at that ride height..
