Any tips on ECU removal....
2003 E55 & 2014 GL550
Gonna try the speedtuningusa.com route and see what happens. Way I see it, if I don't like, I am out 349$...no biggee....then we pull out the 2-3K and go Kleeman and have um reflash and do some pulleys.
Any tips or pics you could share on pulling the ECU...can't find anything. I know you pull the wire plugs in the fuse box....but how does ECU come out...what's holding it in place.
Thanks again.
Thanks again.
1 Post
04E55AMG, 05Dodge RAM 1500 Quad Cab, 02Montero Limited
Thanks again.
Thanks again.
Nothing in particular is holding the ECU in place...it is an interference fit in a plastic holder. Once you remove the black plastic cover on the driver's side, the ECU will be right there. The connectors come off easily but do them in order as they fit closely. As stated above, the Renntech website has a nice "how to" section on the ECU removal. It would be difficult(not impossible) to mess this up.
2005 E55
Thanks again.
Thanks again.
AMG
I'm thinking about it too, one question is it possible to drive the car wouthout the ECU ? I doubt it, just making sure ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Because it's my daily driver and if i'm gonna send the ECU and untill it comes back it's gonna be a while... So i dont know how to do it.
