Does your Command Screen say "AMG"
Old Jan 23, 2005 | 05:54 PM
gmdebruyn's Avatar
2005 E55, 2010 ML350
so for 2005 we can get the E55 to give us the AMG logo.
can any of the techs with the Star system set our cars to the European version so we can have the British voice? What are the downsides of Euro edition aside from the satellite not working?
Old Feb 4, 2005 | 04:36 AM
chem0's Avatar
2004 E55 AMG
Does anyone have pictures of the secret menu?
I have a 2005 E55 and I cant seem to get the 3-5-7 going. Im still not sure on how to do it. Can anyone shine some light?
Old Feb 4, 2005 | 08:43 AM
VinnyC's Avatar
04 MB E55 AMG, 92 911 Turbo
It took me a few times also to get to this menu. I tried both methods but finally got to it by switching to the CD Mode. Once in CD Mode, I turned off the radio. Waited a second, then turned it back on while holding down 3+(5)+7. For me the 5 needed to be pressed slightly before the 3+7. Then then menu appeared. Once you switch the mode to US211-AMG, you need to shut it off and wait a good 5 minutes before you turn it back on or the settings will not stay. I took me a few trys also to make it stay.
Hopefully this helps.
Old Feb 6, 2005 | 03:25 AM
gmdebruyn's Avatar
The NAV mode works as well.
Old Feb 6, 2005 | 03:53 AM
chem0's Avatar
2004 E55 AMG
yay!! i finally got it!!!
because im not in USA.. my setting would be AMG211_ECE
now i have the ///AMG logo on startup instead of boring 3point star.
now i got to find out which setting lets me play dvd's whilst in motion.
Old Feb 6, 2005 | 11:01 AM
cte430's Avatar
'07 Porsche 997TT
Originally Posted by Beowulf
Cool mod - just wish the "AMG" logo would stay up 2 or 3 seconds, rather than half a second. Still, better than the Star.
Even better if the car was on, but the radio was off the AMG logo stayed there!
Old Feb 6, 2005 | 03:49 PM
  #32
Beowulf's Avatar
2005 E55 AMG
Old Feb 6, 2005 | 03:53 PM
  #33
gmdebruyn's Avatar
chem0,
great other post man! I now have an English Accent with my NAV.
http://forums.mbnz.org/forums/forums...hl=secret+menu
Old Feb 6, 2005 | 05:23 PM
  #34
zdkdeeier493's Avatar
AH! Gmdebruyn, that link doesn't work. PLEASE explain the process to me! I want the British voice soooo bad.
Old Feb 6, 2005 | 06:32 PM
  #35
gmdebruyn's Avatar
Sorry about that. Give it a try again (see previous post). I fixed how I inserted the link.
Gareth
Old Feb 7, 2005 | 03:31 PM
  #36
gmdebruyn's Avatar
Let me know if anyone can figure out a way to make this change stick. I tried a few things and the voice stuck, even after I started the car again, but then it reverted back.
Old Apr 3, 2005 | 10:53 PM
  #37
Lov2xlr8's Avatar
does anyone know why this doesnt work on my 04 G55?
Old Apr 3, 2005 | 11:01 PM
  #38
MBE55AMG's Avatar
'03 Yukon XL Denali, '06 Eclipse GS
That's a good question... could it be because of COMAND model difference?
Old Apr 4, 2005 | 02:08 AM
  #39
Lov2xlr8's Avatar
does anyone know what model the 04 G55 has? and how to do it.
Old May 28, 2005 | 10:32 PM
  #40
jcanabal's Avatar
2006 SLK 55 AMG
Will this work on a Comand/Nav SLK 55?
Old May 28, 2005 | 10:57 PM
  #41
Lady Wolf's Avatar
I drive a E55T, SLK55 and 65 Mustang Conv.
Yes, we did it on both our 55's Wolf cross posting as L wolf
Old May 28, 2005 | 11:22 PM
  #42
Rafal's Avatar
2017 S63 Coupe Iridium Silver
Originally Posted by ThemisN
I thought it was found that 3-5-7 stopped working on the 05's...I only tried it once on my car with no luck.
My car is Jan'05 and I used the 3-5-7 method to re-program mine. It works fine, but you must switch off the Command for a few minutes first. Just follow the instructions on the forum.
Old May 29, 2005 | 12:39 AM
  #43
IanSL55's Avatar
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
March '05 here and following the 3-5-7 directions I only managed to set my radio channel to memory setting 3.
TURN ON COMAND | AUDIO | RADIO | HOLDING DOWN 3-5-7
~ Ian
Old May 29, 2005 | 01:23 AM
  #44
xraymd's Avatar
2008 335 vert, 2004 MDX
Instead of radio, try it in CD mode.
Old May 29, 2005 | 09:38 AM
  #45
Rafal's Avatar
~ Ian
Not AUDIO, CD mode with a CD in!
Old May 29, 2005 | 09:41 AM
  #46
Rafal's Avatar
~ Ian
From memory it was 5 first, then while you hold 5, press 3-7 together and the MENU should appear.
Old May 29, 2005 | 05:43 PM
  #47
corgiman's Avatar
E55
OK, so I am now totally confused. After several attempts with the CD in and the system in Nav mode I accessed the 3-5-7 screen and set it to AMGW211_USA. Turned off the system, wait 5 minutes and the MB logo appears. Try again and same results. Oh well.
Stop at the corner store, come back out and now it says AMG! Great except I would like to play with the other settings and I cannot reliably get the system into 3-5-7 mode. Sometimes it comes up and other times not - I can't figure out what I'm doing differently. Any suggestions?
Old May 29, 2005 | 05:59 PM
  #48
MBE55AMG's Avatar
You're correct. It's not the '3-5-7' trick, but rather the '5-3-7' trick.
Make sure you press and hold 5 first, then proceed to pressing and holding 3 and 7.
Old May 29, 2005 | 07:05 PM
  #49
Rafal's Avatar
Chose Euro AMG not US AMG on the menu. When I did US, my TV did not work. Not all cars have a TV tuner so that may not be an issue for you.
Old May 31, 2005 | 01:42 PM
  #50
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
AMG logo
Is there any way to get the radio to switch pre-sets by the steering-wheel rather than scrolling station-to-station?
