Does your Command Screen say "AMG"
04 MB E55 AMG, 92 911 Turbo
I am a newbie, so this may be a stupid question. When I turn on the Radio / Command system, I see the Mercedes Benz Logo. In the showroom, they had a demo command system and when I turned it on, it displayed the "AMG" logo. Should my AMG display the "AMG" logo or the MB Logo??
Is it possible to display the "AMG" logo like the dealer demo?
Super Moderator
It must have been a special demo COMAND unit with a modified boot logo. All COMAND units use the same firmware which have the same Mercedes logo.
You can actually change the logo if you knew how. I know that Steve (MBenzNL) can do it.
Former Vendor of MBWorld
some slow@$$diesels
It is not a demo comand...it is one of those things you can change in 04s and 05s with the 3-5-7 trick as it is called here on the forum...do a search on that.
greetingz,
greetingz,
1 Post
2007 M5, 2004 X3 3.0i
greetingz,
greetingz,
2005 E55, 2010 ML350
yea, i'm about 12 pages in to several posts on 3-5-7 and it seems to be the concensus that it does not work with 05's which can play mp3's.
steve, you're stopping by the bay area in about 2 weeks. is there another way to get the AMG to appear, and to switch the car to Euro setting?
Thanks,
Gareth
Thanks,
Gareth
themis, when was your car delivered/built? can you play mp3's with your car?
check out this monster thread.
https://mbworld.org/forums/showthrea...&highlight=357
seems you have to turn command off for 5 minutes for the setting to take.
I will be thrilled if i can do this with mine, or at least if there is some hope....
1 Post
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I've seen an 04 that was set to ECE and when it was upgraded to the 05 software, that setting mapped to starting with the AMG logo.
-s-
-s-
i just walked outside and tried it on my 05. secret was doing it in the CD mode and depressing 5 a little before 3 and 7, then waiting 5 seconds. but i did pull up the menu. mine is 2005, october build, took delivery end of november.
is it the firmware upgrade that wipes it clean scorchie?
Gareth
Gareth
Gareth
Gareth
-s-
The 357 buttons worked on my 11-03 build date to get the amg logo. I think that's about all you can change with a stock unit.
Scorchie/anyone else that knows,
357 accesss works, AMG logo shows after changing keyboard to USAMG setting. I changed the model setting to the European W211 as well and it took.
Questions:
1) Is it possible that there are other submenus from this 357 access? If so, how do I navigate to them?
2) Specifically, how do I change the language so I get the cool British Navigation voice? Is that at all possible through this method? The European W211 setting does not give me this.
Thanks,
Gareth
Questions:
Thanks,
Gareth
some slow@$$diesels
Originally Posted by ThemisN
I thought it was found that 3-5-7 stopped working on the 05's...I only tried it once on my car with no luck.
Mike...your comand is not broken...Your DAD's W210 comand - however - just starts up differently...just change that - I would say...
greetingz,
thanks steve. i got the AMG to appear with a little coaching from various other posts.
i'm enjoying the current performance of the vehicle, so no worries. i was just interested in changing the NAV voice to the British accent.
Yes!!! The 3-5-7 worked for me also in the CD Mode. The 5 needed to be pressed slightly before the 3+7.
Thank you guys!!! This worked for me on my 04 E55 and now I have the "AMG" logo on my screen!!
