How do you take off the door panels to get to the trim on all 4 doors...
Old Feb 3, 2005 | 04:23 PM
M5KILLR's Avatar
these are the only pieces i cant get off. i took off the access cover under the front door's side view mirror and this wood strip (1st one i got to) was held on by a nut. So i am assuming they are all bolted on and i dont know how to take off the upper panel. any help is appreciated.
Old Feb 3, 2005 | 09:23 PM
tjcMBE55AMG's Avatar
2002 MB E55 AMG
Peter ... I've done it with W210 (for birdseye maple door handles) ... I'll see if I can find the post with directions. Not sure how different W211 is.
TJC
Old Feb 3, 2005 | 09:37 PM
2002 MB E55 AMG
My post is long gone ... but here are the W210 instructions (from actual experience):
Removing a W210 door panel –
The door panel is held in place by 3 major screws and a number of metal and plastic clips. Here is the removal process, assuming that you need to get the panel off to install something like aftermarket door handles. Time to complete each – 20 minutes or better.
(1) Tools – T25 Torx driver, Phillips and standard screwdriver, strong fingers. It helps to have two other inexpensive tools (available at Pep Boys) – 1) a wide flat plastic body putty tool (looks like a small machete) for slipping between panel and door and 2) panel clip popping tool (looks like a flat spoon with a v-groove). Obtain extra plastic clips first (dealer) in case you break or lose any (I didn't).
(2) First, roll down the window all the way. Remove the door latch escutcheon with a single small screw. Remove the door lock (unscrews). Gently pry off the ‘SRS’ plastic cover near the airbag (one screw is underneath). Pop off the round cover below the door handle (one screw is underneath). Carefully pry out the plastic finger cup behind the door handle – easiest by starting toward the front of the door (one screw is underneath). Remove all 3 screws (Phillips) and set carefully aside.
(3) Starting at the bottom of the door, insert a thin tool (plastic body tool) between the door panel and the door. This will allow you to see the clips and pop at each one with the panel clip popping tool. Work from the bottom up to the last clip just below the wood insert trim. They pop with relatively little force.
(4) The top of the door panel is held in place with a number of metal clips which hold the top turned-down edge of the door panel. After popping all the clips, start at the latch end (rear) of the door and lift underneath slightly to loosen the rear clip. Then stand with your body against the door panel and put fingertips of both hands just behind the window (not into the window slot) on the top of the door panel. The rubber window gasket stays in place. Pull fingertips toward you and lift slightly and the door panel will ‘pop off’ suddenly. Lift up and over the door lock arm, which swings down. Take care to chase down and re-set any metal clips that fly off.
(5) Look over the top of the panel, holding it against your body and locate the door latch hook mechanism. Pull forward slightly to take pressure off and unhook. Pull on the hook again to expose cable and slip the bare cable up through the cable guide to free the door panel. There is enough slack in wiring to switches and puddle lights to actually swing the door panel into the car door opening in order to access parts inside the panel.
(6) If you are replacing the door handles, use the Torx T-25 to remove one screw at the base of the door handle and two T-25s at the top of the handle. You may have to pull back some of the adhered sound-deading material. All the torx screws are on the inside face of the door panel. The handle can now be removed. Reverse operation to re-install.
TJC
