How to debadge?
- Using the dental floss, start to pry the badges off by working the floss back and forth behind the letters. Pull the dental floss away from the car so that it is rubbing on the badge and not the car. If there is much resistance to the dental floss while cutting the adhesive, reheat the badge for about a minute and try again.
-With the badge off you now have to deal with the leftover adhesive. Use some goo-gone and either a rag or paper towel and rub the remaining black gunk off. After everything is off, finish off with some wax.
I used the hair dryer and fingernail technique. It's pretty easy. Just make sure you give the area a good clean after you are done to remove excess glue. A little bit of wax does the trick.
We're getting our E55 delivered in a week at a different dealer. I hope they know how to pull them off properly. We're going from one end of the E spectrum to the other but are staying stealth.
on a benz i would do the denta floss, then with the tape that is left you can usually grap be with your fingers and pill it off. if this does not work try rolling it up. I would not use goo gone or goop off nothing like that. If you do use something just use that wax/bug/tar remover. also if its a dark color dont rub it real hard cause it will scratch the clear coat.
