Door Lock Pins
Door Lock Pins
Can't seem to find any good info out there on replacing the door lock pins. Seems to be some differing opinions out there as to whether both the front door and back door pins can be easily swapped out with better looking metal pins. Has anyone tried to replace their door lock pins and if so can you describe how to get the original pins off? Is it as simple as a counterclockwise twist to remove?
Trying to find this out at this very moment. Did you have any luck?
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Might want to check out this thread on the W212 forums.
https://mbworld.org/forums/e-class-w...door-pins.html
Buddy at the dealer told me they push on..front and back w212...doing some more digging though...problem now...Im not sure which ones are the front ones? One set is tapered at the bottom..one is not..any thoughts?...I will be doing this at home this weekend....
'11 350 4matic - '14 Stingray: Gone, BMW 530i, Porsche 944 Turbo, Porsche 356, Mitsubishi 3000GT
Please post your results. I'm getting my stainless steel ones in this week. Thanks!!!
